[MOAB-dev] r4601 - MOAB/trunk/src/parallel
kraftche at cae.wisc.edu kraftche at cae.wisc.edu
Tue Mar 15 19:57:17 CDT 2011
Author: kraftche
Date: 2011-03-15 19:57:17 -0500 (Tue, 15 Mar 2011)
New Revision: 4601
Modified:
   MOAB/trunk/src/parallel/WriteHDF5Parallel.cpp
Log:
fix debug output in parallel hdf5 writer
Modified: MOAB/trunk/src/parallel/WriteHDF5Parallel.cpp
--- MOAB/trunk/src/parallel/WriteHDF5Parallel.cpp	2011-03-16 00:46:56 UTC (rev 4600)
+++ MOAB/trunk/src/parallel/WriteHDF5Parallel.cpp	2011-03-16 00:57:17 UTC (rev 4601)
@@ -820,8 +820,8 @@
         assert(citer != sums.end());
         num_val = *citer; ++citer;
-      dbgOut.printf( 2, "Creating table of size %lu for tag 0x%lx\n",
-                     num_val ? num_val : num_ents, (unsigned long)tag_iter->tag_id );
+      dbgOut.printf( 2, "Writing tag description for tag 0x%lx with %lu values\n",
+                     (unsigned long)tag_iter->tag_id, num_val ? num_val : num_ents );
       rval = create_tag( *tag_iter, num_ents, num_val );
       if (MB_SUCCESS != rval)
