Author: jvporter
Date: 2011-03-14 16:54:53 -0500 (Mon, 14 Mar 2011)
New Revision: 4588
Modified:
MOAB/trunk/itaps/imesh/iMesh_MOAB.cpp
Log:
Make iMesh_(get|set)AdjTable mostly obey the spec (this is a hacky solution,
but the spec is in flux anyway).
Modified: MOAB/trunk/itaps/imesh/iMesh_MOAB.cpp
--- MOAB/trunk/itaps/imesh/iMesh_MOAB.cpp 2011-03-14 21:54:09 UTC (rev 4587)
+++ MOAB/trunk/itaps/imesh/iMesh_MOAB.cpp 2011-03-14 21:54:53 UTC (rev 4588)
@@ -256,6 +256,17 @@
tags[w++] = tags[r];
+// modify the adjacency table to match the ITAPS spec's expectations
+static void munge_adj_table(int *adjTable, int geom_dim)
+ if (geom_dim == 2) {
+ for (size_t i = 0; i < 16; ++i) {
+ if (i % 4 == 3 || i >= 12)
+ adjTable[i] = iBase_UNAVAILABLE;
#ifdef __cplusplus
extern "C" {
#endif
@@ -443,8 +454,12 @@
/*inout*/ int* adjacency_table_allocated,
/*out*/ int* adjacency_table_size, int *err)
+ int geom_dim;
+ iMesh_getGeometricDimension(instance, &geom_dim, err);
ALLOC_CHECK_ARRAY_NOFAIL(adjacency_table, 16);
memcpy(*adjacency_table, MBIMESHI->AdjTable, 16*sizeof(int));
+ munge_adj_table(*adjacency_table, geom_dim);
RETURN(iBase_SUCCESS);
@@ -457,7 +472,11 @@
RETURN(iBase_INVALID_ARGUMENT);
+ int geom_dim;
memcpy(MBIMESHI->AdjTable, adj_table, 16*sizeof(int));
+ munge_adj_table(adj_table, geom_dim);
