[MOAB-dev] r4567 - in MOAB/trunk/src/parallel: . moab
    hongjun at mcs.anl.gov
    Wed Mar  9 23:50:50 CST 2011
Author: hongjun
Date: 2011-03-09 23:50:49 -0600 (Wed, 09 Mar 2011)
New Revision: 4567
Modified:
   MOAB/trunk/src/parallel/ParallelComm.cpp
   MOAB/trunk/src/parallel/moab/ParallelComm.hpp
Log:
o Tab characters are removed from the code
o get_num_buff_procs is removed
o buff_procs is set as const function
o Passes "make check" except read_cgm test because of using OCC CGM
Modified: MOAB/trunk/src/parallel/ParallelComm.cpp
--- MOAB/trunk/src/parallel/ParallelComm.cpp	2011-03-10 00:04:07 UTC (rev 4566)
+++ MOAB/trunk/src/parallel/ParallelComm.cpp	2011-03-10 05:50:49 UTC (rev 4567)
@@ -586,9 +586,9 @@
 ErrorCode ParallelComm::scatter_entities( const int from_proc,
-					  std::vector<Range> &entities,
-					  const bool adjacencies,
-					  const bool tags)
+                                          std::vector<Range> &entities,
+                                          const bool adjacencies,
+                                          const bool tags)
 #ifndef USE_MPI
   return MB_FAILURE;
@@ -613,7 +613,7 @@
       result = add_verts(entities[i]);
       result = pack_buffer(entities[i], adjacencies, tags,
-			   false, -1, &buff);
+                           false, -1, &buff);
       RRA("Failed to compute buffer size in scatter_entities.");
       buff_size = buff.buff_ptr - buff.mem_ptr - prev_size;
@@ -638,8 +638,8 @@
   // scatter actual geometry
   success = MPI_Scatterv(buff.mem_ptr, sendCounts, displacements,
-			 MPI_UNSIGNED_CHAR, rec_buff.mem_ptr, sendCounts[my_proc],
-			 MPI_UNSIGNED_CHAR, from_proc, procConfig.proc_comm());
+                         MPI_UNSIGNED_CHAR, rec_buff.mem_ptr, sendCounts[my_proc],
+                         MPI_UNSIGNED_CHAR, from_proc, procConfig.proc_comm());
   if (MPI_SUCCESS != success) {
     result = MB_FAILURE;
@@ -664,17 +664,17 @@
 ErrorCode ParallelComm::send_entities(const int to_proc,
-				      Range &orig_ents,
-				      const bool adjs,
-				      const bool tags,
-				      const bool store_remote_handles,
-				      const bool is_iface,
-				      Range &final_ents,
-				      int &incoming1,
-				      int &incoming2,
-				      tuple_list& entprocs,
-				      std::vector<MPI_Request> &recv_remoteh_reqs,
