[MOAB-dev] r4555 - in MOAB/trunk/src: . io
tautges at mcs.anl.gov
Wed Mar 9 00:22:25 CST 2011
Author: tautges
Date: 2011-03-09 00:22:24 -0600 (Wed, 09 Mar 2011)
New Revision: 4555
Modified:
MOAB/trunk/src/ScdInterface.cpp
MOAB/trunk/src/io/ReadNC.cpp
Log:
ScdInterface: fixing a paste-o spotted by Iulian; also changing tag types to
sparse, we'll likely have very few blocks of structured mesh in any mesh.
ReadNC: change handling of timestep data so if only a single timestep is there
it gets read in.
Modified: MOAB/trunk/src/ScdInterface.cpp
--- MOAB/trunk/src/ScdInterface.cpp 2011-03-09 06:11:03 UTC (rev 4554)
+++ MOAB/trunk/src/ScdInterface.cpp 2011-03-09 06:22:24 UTC (rev 4555)
@@ -183,7 +183,7 @@
if (MB_SUCCESS != rval) return rval;
// tag the set with the box
- rval = mbImpl->tag_set_data(box_set_tag(), &scd_set, 1, low.hom_coord());
+ rval = mbImpl->tag_set_data(box_set_tag(), &scd_set, 1, &new_box);
return MB_SUCCESS;
@@ -211,7 +211,7 @@
if (boxMinTag || !create_if_missing) return boxMinTag;
- ErrorCode rval = mbImpl->tag_create("BOX_MIN", 3*sizeof(int), MB_TAG_DENSE,
+ ErrorCode rval = mbImpl->tag_create("BOX_MIN", 3*sizeof(int), MB_TAG_SPARSE,
MB_TYPE_OPAQUE, boxMinTag, NULL, true);
if (MB_SUCCESS != rval) return 0;
return boxMinTag;
@@ -221,7 +221,7 @@
if (boxMaxTag || !create_if_missing) return boxMaxTag;
- ErrorCode rval = mbImpl->tag_create("BOX_MAX", 3*sizeof(int), MB_TAG_DENSE,
+ ErrorCode rval = mbImpl->tag_create("BOX_MAX", 3*sizeof(int), MB_TAG_SPARSE,
MB_TYPE_OPAQUE, boxMaxTag, NULL, true);
return boxMaxTag;
@@ -231,7 +231,7 @@
if (boxSetTag || !create_if_missing) return boxSetTag;
- ErrorCode rval = mbImpl->tag_create("__BOX_SET", 3*sizeof(int), MB_TAG_DENSE,
+ ErrorCode rval = mbImpl->tag_create("__BOX_SET", sizeof(ScdBox*), MB_TAG_SPARSE,
MB_TYPE_OPAQUE, boxSetTag, NULL, true);
return boxSetTag;
Modified: MOAB/trunk/src/io/ReadNC.cpp
--- MOAB/trunk/src/io/ReadNC.cpp 2011-03-09 06:11:03 UTC (rev 4554)
+++ MOAB/trunk/src/io/ReadNC.cpp 2011-03-09 06:22:24 UTC (rev 4555)
@@ -343,7 +343,9 @@
for (mit = varInfo.begin(); mit != varInfo.end(); mit++) {
VarData vd = (*mit).second;
std::vector<int> tmp_v;
- tmp_v.push_back(tDim);
+ if (-1 != tMin &&
