[MOAB-dev] r4549 - MOAB/trunk/test/h5file
kraftche at cae.wisc.edu kraftche at cae.wisc.edu
Tue Mar 8 10:47:22 CST 2011
Author: kraftche
Date: 2011-03-08 10:47:22 -0600 (Tue, 08 Mar 2011)
New Revision: 4549
Modified:
   MOAB/trunk/test/h5file/h5sets_test.cpp
Log:
re-enalbe some tests of HDF5 writer that I accidentally left disabled at some point
Modified: MOAB/trunk/test/h5file/h5sets_test.cpp
--- MOAB/trunk/test/h5file/h5sets_test.cpp	2011-03-08 16:37:37 UTC (rev 4548)
+++ MOAB/trunk/test/h5file/h5sets_test.cpp	2011-03-08 16:47:22 UTC (rev 4549)
@@ -325,9 +325,9 @@
   // only one test so far... should probably add second test
   // for really-old-format  entityset parent/child links
   int exitval = 0;
-  //exitval += RUN_TEST( test_ranged_set_with_holes );
-  //exitval += RUN_TEST( test_file_set );
-  //exitval += RUN_TEST( test_small_tree );
+  exitval += RUN_TEST( test_ranged_set_with_holes );
+  exitval += RUN_TEST( test_file_set );
+  exitval += RUN_TEST( test_small_tree );
   exitval += RUN_TEST( regression_mmiller_8_2010 );
   if (do_big_tree_test) {
     exitval += RUN_TEST( test_big_tree );
