[MOAB-dev] r4544 - MOAB/trunk/src/io
kraftche at cae.wisc.edu kraftche at cae.wisc.edu
Mon Mar 7 19:06:57 CST 2011
Author: kraftche
Date: 2011-03-07 19:06:57 -0600 (Mon, 07 Mar 2011)
New Revision: 4544
Modified:
   MOAB/trunk/src/io/WriteHDF5.cpp
Log:
remove invalid assert from HDF5 writer
Modified: MOAB/trunk/src/io/WriteHDF5.cpp
--- MOAB/trunk/src/io/WriteHDF5.cpp	2011-03-08 01:05:55 UTC (rev 4543)
+++ MOAB/trunk/src/io/WriteHDF5.cpp	2011-03-08 01:06:57 UTC (rev 4544)
@@ -1100,7 +1100,7 @@
       dbgOut.print(2, "Writing set parent lists\n" );
       break;
-  assert(max_vals > 0); // should have skipped this function otherwise
+  //assert(max_vals > 0); // should have skipped this function otherwise
   // buffer to use for IO
   id_t* buffer = reinterpret_cast<id_t*>(dataBuffer);
