[MOAB-dev] r4535 - MOAB/trunk/src/io
iulian at mcs.anl.gov
Mon Feb 28 17:16:06 CST 2011
Author: iulian
Date: 2011-02-28 17:16:06 -0600 (Mon, 28 Feb 2011)
New Revision: 4535
Modified:
MOAB/trunk/src/io/WriteSmf.cpp
Log:
case when output sets are provided was not implemented
Modified: MOAB/trunk/src/io/WriteSmf.cpp
--- MOAB/trunk/src/io/WriteSmf.cpp 2011-02-28 21:00:18 UTC (rev 4534)
+++ MOAB/trunk/src/io/WriteSmf.cpp 2011-02-28 23:16:06 UTC (rev 4535)
@@ -109,9 +109,9 @@
else
- // not implemented yet, get out
- // support export only of all triangles from the mesh
- return MB_NOT_IMPLEMENTED;
+ // get all triangles from output sets
+ for (int i=0; i<num_sets; i++)
+ rval = mbImpl->get_entities_by_type( output_list[i], MBTRI, triangles, false);
// use an array with all the connectivities in the triangles; it will be converted later to ints
int numTriangles = triangles.size();
