[MOAB-dev] r4528 - in MOAB/trunk/src/io: . mhdf/src
kraftche at cae.wisc.edu
Thu Feb 24 13:08:51 CST 2011
Author: kraftche
Date: 2011-02-24 13:08:51 -0600 (Thu, 24 Feb 2011)
New Revision: 4528
Modified:
MOAB/trunk/src/io/ReadHDF5.cpp
MOAB/trunk/src/io/mhdf/src/file.c
Log:
make moab_test pass when moab is built with parallel hdf5 support
Modified: MOAB/trunk/src/io/ReadHDF5.cpp
--- MOAB/trunk/src/io/ReadHDF5.cpp 2011-02-24 17:41:11 UTC (rev 4527)
+++ MOAB/trunk/src/io/ReadHDF5.cpp 2011-02-24 19:08:51 UTC (rev 4528)
@@ -96,7 +96,9 @@
static herr_t handle_hdf5_error( hid_t stack, void* data )
ReadHDF5::HDF5ErrorHandler* h = reinterpret_cast<ReadHDF5::HDF5ErrorHandler*>(data);
- herr_t result = (*h->func)(stack,h->data);
+ herr_t result = 0;
+ if (h->func)
+ result = (*h->func)(stack,h->data);
error(MB_FAILURE);
return result;
@@ -104,7 +106,9 @@
static herr_t handle_hdf5_error( void* data )
- herr_t result = (*h->func)(h->data);
+ if (h->func)
+ result = (*h->func)(h->data);
error(MB_FAILURE);
return result;
Modified: MOAB/trunk/src/io/mhdf/src/file.c
--- MOAB/trunk/src/io/mhdf/src/file.c 2011-02-24 17:41:11 UTC (rev 4527)
+++ MOAB/trunk/src/io/mhdf/src/file.c 2011-02-24 19:08:51 UTC (rev 4528)
@@ -22,6 +22,10 @@
#include <H5Spublic.h>
#include <H5Tpublic.h>
#include <H5Apublic.h>
+#ifdef HDF5_PARALLEL
+# include <H5FDmpi.h>
+# include <H5FDmpio.h>
+#endif
#include "mhdf.h"
#include "status.h"
#include "names-and-paths.h"
@@ -291,17 +295,34 @@
FileHandle* file_ptr;
unsigned int flags;
hid_t group_id;
+ herr_t err;
+ int check_is_hdf5 = 1;
+ MPI_Comm comm;
+ MPI_Info info;
