[MOAB-dev] r4526 - MOAB/trunk/config
kraftche at cae.wisc.edu kraftche at cae.wisc.edu
Thu Feb 24 10:15:49 CST 2011
Author: kraftche
Date: 2011-02-24 10:15:49 -0600 (Thu, 24 Feb 2011)
New Revision: 4526
Modified:
   MOAB/trunk/config/netcdf.m4
Log:
fix configure with NetCDF that requires HDF5 but not libcurl
Modified: MOAB/trunk/config/netcdf.m4
--- MOAB/trunk/config/netcdf.m4	2011-02-23 23:42:24 UTC (rev 4525)
+++ MOAB/trunk/config/netcdf.m4	2011-02-24 16:15:49 UTC (rev 4526)
@@ -97,15 +97,17 @@
                     [FATHOM_CHECK_NETCDF_LIMITS([$1],[$2],[netcdf.h],[NETCDF_SUFFICIENT_DIM_VARS])],
                     [AC_MSG_WARN([[NetCDF header not found.]]); HAVE_NETCDF=no] )
+      # Check if netcdf is usable by itself
   AC_CHECK_LIB( [netcdf], [nc_create], [NETCDF_LIBS="-lnetcdf"], [
+      # Check if netcdf is usable with HDF5
     unset ac_cv_lib_netcdf
     unset ac_cv_lib_netcdf_nc_create
       # If we haven't already looked for HDF5 libraries, again now incase
       # they're in the NetCDF lib directory.
     FATHOM_DETECT_HDF5_LIBS
     LDFLAGS="$LDFLAGS $HDF5_LDFLAGS"
-    NETCDF_LDFLAGS="$NETCDF_LDFLAGS"
-    AC_CHECK_LIB( [netcdf], [nc_create], [NETCDF_LIBS="-lnetcdf"], [
+    AC_CHECK_LIB( [netcdf], [nc_create], [NETCDF_LIBS="-lnetcdf -lhdf5_hl"], [
+      # Try one more time with HDF5 and libcurl
       AC_CHECK_LIB( [netcdf], [nc_create], [NETCDF_LIBS="-lnetcdf -lhdf5_hl -lcurl"],
