[MOAB-dev] build error on mcs machines
Jason Kraftcheck kraftche at cae.wisc.edu
Thu Feb 24 10:06:29 CST 2011
On 02/24/2011 10:01 AM, Hong-Jun Kim wrote:
> Our system have 2 different versions of "mpicc/mpicxx" under "/usr" and "/usr/lib/mpich" as follows.
> I used the following configuration to build MOAB.
> (--prefix=/homes/hongjun/lib/MOAB-new --with-mpi
> --with-cgm=/homes/hongjun/lib/CGM --enable-debug
> --disable-optimize
> --enable-igeom --enable-imesh --enable-dagmc)
> So, I think there is no other dependencies built with a different mpicc/mpicxx.
Does it work if you add "--without-hdf5 --without-netcdf"?
- jason
