[MOAB-dev] strange compile errors
Tim Tautges
tautges at mcs.anl.gov
Thu Feb 17 10:51:03 CST 2011
This has to do with the --enable-shared in the first configure and not the second. It appears that the hdf5 libs under
/home/fathom weren't compiled shared.
- tim
On 02/17/2011 10:05 AM, Iulian Grindeanu wrote:
> On Argonne machines, I am seeing some errors that I do not understand (and did not see yesterday).
> Does anybody know what is going on?
> configuring with:
> ./configure --prefix=/home/iulian/lib/serial/moab --with-cgm=/home/iulian/lib/serial/cg
> m --with-netcdf=/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc --with-hdf5=/homes
> /fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc --with-zlib=/homes/fathom/3rdparty/zlib/zlib
> -1.2.4/gcc --with-szip=/homes/fathom/3rdparty/szip/szip-2.1/gcc --enable-debug --enable-
> imesh --enable-shared
> I get this error:
> make[4]: Entering directory `/nfs/mcs-homes129/iulian/serial/MOAB/src'
> CXXLD libMOAB.la
> /usr/bin/ld: /homes/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.a(H5.o): relocation R_X86_64_32 against `H5_debug_g' can not be used when making a shared object; recompile with -fPIC
> /homes/fathom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/lib/libhdf5.a: could not read
> When I configure with:
> ./configure --prefix=/home/iulian/cub12/lib/moab --with-cgm=/home/iulian/cub12/lib/cgm
> --with-netcdf=/homes/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc --with-hdf5=/homes/f
> athom/3rdparty/hdf5/hdf5-1.8.3/serial/gcc --with-zlib=/homes/fathom/3rdparty/zlib/zlib-1
> .2.4/gcc --with-szip=/homes/fathom/3rdparty/szip/szip-2.1/gcc --enable-debug --enable-im
> esh
> it goes a little further, but fails due to HDF5 references:
> make[2]: Entering directory `/nfs/mcs-homes129/iulian/cub12/MOAB/tools'
> Making all in .
> make[3]: Entering directory `/nfs/mcs-homes129/iulian/cub12/MOAB/tools'
> CXXLD mbconvert
> /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so: undefined reference to `H5DSiterate_scales'
> /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so: undefined reference to `H5DSattach_scale'
> /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so: undefined reference to `H5DSget_num_scales'
> /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so: undefined reference to `H5DSset_scale'
> /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so: undefined reference to `H5DSget_scale_name'
> /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so: undefined reference to `H5DSis_scale'
> /home/fathom/3rdparty/netcdf/netcdf-4.0.1/serial/gcc/lib/libnetcdf.so: undefined reference to `H5DSdetach_scale'
> collect2: ld returned 1 exit status
> make[3]: *** [mbconvert] Error 1
> make[3]: Leaving directory `/nfs/mcs-homes129/iulian/cub12/MOAB/tools'
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
