[MOAB-dev] r4508 - MOAB/trunk/itaps/imesh
Iulian Grindeanu iulian at mcs.anl.gov
Thu Feb 17 09:31:27 CST 2011
As always, I hate when the "interface" changes.
Right now, MOAB with enable-igeom will not compile, because of this change. I assume there are other places ( in MeshKit) that use get/set tag methods.
Iulian
----- Original Message -----
> Whoops, forgot one item: this also changes the char* to void* in
> iMesh_(get|set)Data and friends.
> On Wed, 2011-02-16 at 16:38 -0600, jvporter at wisc.edu wrote:
> > Author: jvporter
> > Date: 2011-02-16 16:38:33 -0600 (Wed, 16 Feb 2011)
> > New Revision: 4508
> > Modified:
> >    MOAB/trunk/itaps/imesh/iMesh.h
> >    MOAB/trunk/itaps/imesh/iMesh_MOAB.cpp
> >    MOAB/trunk/itaps/imesh/testc_cbind.c
> > Log:
> > Mostly sync iMesh.h with standard version:
> > * Add/update comments
> > * Add iMesh_(get|set)ESHData and friends
> > Still left to do:
> > * Figure out whose num_hops comments are correct (I think ours)
> > * Do something about iMesh_setAdjTable
> > Modified: MOAB/trunk/itaps/imesh/iMesh.h
> > --- MOAB/trunk/itaps/imesh/iMesh.h 2011-02-16 21:59:14 UTC (rev
> > 4507)
> > +++ MOAB/trunk/itaps/imesh/iMesh.h 2011-02-16 22:38:33 UTC (rev
> > 4508)
> > @@ -7,7 +7,7 @@
> >    /**\brief iMesh Interface Specification Minor Release Number
> > -#define IMESH_MINOR_VERSION 0
> > +#define IMESH_MINOR_VERSION 1
> >    /**\brief iMesh Interface Specification Patch Release Number
> > @@ -30,7 +30,7 @@
> >     * to this interface, for example mesh smoothing, adaptive mesh
> >     refinement,
> >     * and parallel mesh support.
> > - * \section DataModel Data Model
> > + * \section ITAPS Data Model
> >     * The ITAPS interfaces use a data model composed of four basic
> >     data types: \n
> >     * \em Entity: basic topological entities in a mesh, e.g.
> >     vertices,
> > @@ -45,7 +45,7 @@
> >     * \em Tag: application data associated with objects of any of
> >     the other
> >     * data types. Each tag has a designated name, size, and data
> >     type.
> > - * \section TypeTopology Entity Type, Topology
> > + * \section ITAPS Entity Type, Topology
> >     * Each entity has a specific Entity Type and Entity Topology.
> >     The Entity
> >     * Type is one of VERTEX, EDGE, FACE, and REGION, and is
> >     synonymous with
> >     * the topological dimension of the entity. The Entity Topology
> >     denotes
> > @@ -54,14 +54,14 @@
> >     * types, Entity Type in the iBase_EntityType enumeration, and
> >     * Entity Topology in the iMesh_EntityTopology enumeration.
> > - * \section Access Entity-, Array-, and Iterator-Based Access
> > + * \section ITAPS Entity-, Array-, and Iterator-Based Access
> >     * The iMesh interface provides functions for accessing entities
> >     * individually, as arrays of entities, or using iterators. These
> >     access
> >     * methods have different memory versus execution time tradeoffs,
> >     * depending on the implementation.
> > - * \section Lists Lists Passed Through Interface
> > + * \section ITAPS Lists Passed Through Interface
> >     * Many of the functions in iMesh have arguments corresponding to
> >     lists of
> >     * objects. In-type arguments for lists consist of a pointer to
> >     an array and
> > @@ -79,7 +79,7 @@
> >     * INTERFACE IMPLEMENTATIONS IS DONE USING THE C MALLOC FUNCTION,
> >     AND CAN BE
> >     * DE-ALLOCATED USING THE C FREE FUNCTION.
