[MOAB-dev] buildbot failure in Fathom on moab-distcheck
Tim Tautges tautges at mcs.anl.gov
Tue Feb 15 08:53:36 CST 2011
See the src/parallel/Makefile.am for an example of how this is done.
- tim
On 02/15/2011 08:28 AM, Iulian Grindeanu wrote:
> Sorry about that.
> Makefile.am should have included extra headers, needed for build, but not part of the installation.
> Anyway, in the current form, there is a new library added to the installation, and I do not think it is necessary. It should be probably included in libMOAB.a. How do I do that in the Makefile.am?
> Thanks,
> Iulian
>> The Fathomatic has detected a failed build of moab-distcheck on
>> Fathom.
>> Full details are available at:
>> http://gnep.mcs.anl.gov:8010/builders/moab-distcheck/builds/412
>> Buildbot URL: http://gnep.mcs.anl.gov:8010/
>> Buildslave for this Build: gnep
>> Build Reason: The Nightly scheduler named 'nightly' triggered this
>> build
>> Build Source Stamp: None
>> Blamelist:
>> BUILD FAILED: failed compile
>> LOG EXCERPT:
>> mv -f .deps/quads_to_tris.Tpo .deps/quads_to_tris.Po
>> /bin/sh ../../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic
>> -Wno-long-long -O2 -DNDEBUG -o quads_to_tris quads_to_tris_driver.o
>> quads_to_tris.o ../../src/libMOAB.la -lm
>> g++ -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -o quads_to_tris
>> quads_to_tris_driver.o quads_to_tris.o ../../src/.libs/libMOAB.a
>> -lnetcdf -L/usr/lib/mpich/lib/ /usr/lib/libhdf5.so -lpthread -lz -lm
>> Making all in mbfacetgeom
>> make[5]: Entering directory
>> `/disk/itaps-buildslave/moab-distcheck/build/moab-4.99/_build/tools/mbfacetgeom'
>> /bin/sh ../../libtool --tag=CXX --mode=compile g++ -DHAVE_CONFIG_H -I.
>> -I../../../tools/mbfacetgeom -I../.. -I../../src/moab
>> -I../../src/parallel -I../../src -DTEMPLATE_SPECIALIZATION
>> -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64
>> -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB
>> -DMESHDIR=../../../MeshFiles/unittest -I../../../src -I../../src
>> -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map
>> -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT FBEngine.lo -MD
>> -MP -MF .deps/FBEngine.Tpo -c -o FBEngine.lo
>> ../../../tools/mbfacetgeom/FBEngine.cpp
>> g++ -DHAVE_CONFIG_H -I. -I../../../tools/mbfacetgeom -I../..
>> -I../../src/moab -I../../src/parallel -I../../src
>> -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION
>> -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64 -DHDF5_FILE -DNETCDF_FILE
>> -DIS_BUILDING_MB -DMESHDIR=../../../MeshFiles/unittest -I../../../src
>> -I../../src -DUNORDERED_MAP_NS=std::tr1
>> -DHAVE_UNORDERED_MAP=tr1/unordered_map -Wall -pipe -pedantic
>> -Wno-long-long -O2 -DNDEBUG -MT FBEngine.lo -MD -MP -MF
>> .deps/FBEngine.Tpo -c ../../../tools/mbfacetgeom/FBEngine.cpp -o
>> FBEngine.o
>> ../../../tools/mbfacetgeom/FBEngine.cpp:14:27: error: SmoothCurve.hpp:
>> No such file or directory
>> ../../../tools/mbfacetgeom/FBEngine.cpp:15:26: error: SmoothFace.hpp:
>> ../../../tools/mbfacetgeom/FBEngine.cpp: In destructor
>> 'FBEngine::~FBEngine()':
>> ../../../tools/mbfacetgeom/FBEngine.cpp:54: warning: possible problem
>> detected in invocation of delete operator:
>> ../../../tools/mbfacetgeom/FBEngine.cpp:54: warning: invalid use of
>> incomplete type 'struct SmoothCurve'
>> ../../../tools/mbfacetgeom/FBEngine.hpp:20: warning: forward
>> declaration of 'struct SmoothCurve'
>> ../../../tools/mbfacetgeom/FBEngine.cpp:54: note: neither the
>> destructor nor the class-specific operator delete will be called, even
>> if they are declared when the class is defined.
>> ../../../tools/mbfacetgeom/FBEngine.cpp:59: warning: possible problem
>> ../../../tools/mbfacetgeom/FBEngine.cpp:59: warning: invalid use of
>> incomplete type 'struct SmoothFace'
>> ../../../tools/mbfacetgeom/FBEngine.hpp:19: warning: forward
>> declaration of 'struct SmoothFace'
>> ../../../tools/mbfacetgeom/FBEngine.cpp:59: note: neither the
>> ../../../tools/mbfacetgeom/FBEngine.cpp: In member function
>> 'moab::ErrorCode FBEngine::initializeSmoothing()':
>> ../../../tools/mbfacetgeom/FBEngine.cpp:103: error:
>> 'GEOM_DIMENSION_TAG_NAME' was not declared in this scope
>> ../../../tools/mbfacetgeom/FBEngine.cpp:105: error:
>> 'GLOBAL_ID_TAG_NAME' was not declared in this scope
>> ../../../tools/mbfacetgeom/FBEngine.cpp:119: error: invalid use of
>> ../../../tools/mbfacetgeom/FBEngine.hpp:19: error: forward declaration
>> ../../../tools/mbfacetgeom/FBEngine.cpp:134: error: invalid use of
>> ../../../tools/mbfacetgeom/FBEngine.hpp:20: error: forward declaration
>> ../../../tools/mbfacetgeom/FBEngine.cpp:140: error: invalid use of
>> ../../../tools/mbfacetgeom/FBEngine.cpp:141: error: invalid use of
>> ../../../tools/mbfacetgeom/FBEngine.cpp:180: error: invalid use of
>> ../../../tools/mbfacetgeom/FBEngine.cpp:182: error: invalid use of
>> ../../../tools/mbfacetgeom/FBEngine.cpp:191: error: invalid use of
>> ../../../tools/mbfacetgeom/FBEngine.cpp:199: error: invalid use of
>> ../../../tools/mbfacetgeom/FBEngine.cpp:211: error: invalid use of
>> 'moab::ErrorCode FBEngine::getEntClosestPt(moab::EntityHandle, double,
>> double, double, double*, double*, double*)':
>> ../../../tools/mbfacetgeom/FBEngine.cpp:413: error: invalid use of
>> 'moab::ErrorCode FBEngine::getEntNrmlXYZ(moab::EntityHandle, double,
>> ../../../tools/mbfacetgeom/FBEngine.cpp:504: error: invalid use of
>> 'moab::ErrorCode FBEngine::getPntRayIntsct(double, double, double,
>> double, double, double, std::vector<long unsigned int,
>> std::allocator<long unsigned int>  >&, std::vector<double,
>> std::allocator<double>  >&, std::vector<double, std::allocator<double>
>> ../../../tools/mbfacetgeom/FBEngine.cpp:595: warning: comparison
>> between signed and unsigned integer expressions
>> ../../../tools/mbfacetgeom/FBEngine.cpp:605: warning: comparison
>> ../../../tools/mbfacetgeom/FBEngine.cpp:619: error: invalid use of
>> sincerely,
>> -The Fathomatic
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
