[MOAB-dev] buildbot failure in Fathom on moab-distcheck
moab-dev at mcs.anl.gov
Tue Feb 15 00:26:41 CST 2011
The Fathomatic has detected a failed build of moab-distcheck on Fathom.
Full details are available at:
http://gnep.mcs.anl.gov:8010/builders/moab-distcheck/builds/412
Buildbot URL: http://gnep.mcs.anl.gov:8010/
Buildslave for this Build: gnep
Build Reason: The Nightly scheduler named 'nightly' triggered this build
Build Source Stamp: None
Blamelist:
BUILD FAILED: failed compile
LOG EXCERPT:
mv -f .deps/quads_to_tris.Tpo .deps/quads_to_tris.Po
/bin/sh ../../libtool --tag=CXX --mode=link g++ -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -o quads_to_tris quads_to_tris_driver.o quads_to_tris.o ../../src/libMOAB.la -lm
g++ -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -o quads_to_tris quads_to_tris_driver.o quads_to_tris.o ../../src/.libs/libMOAB.a -lnetcdf -L/usr/lib/mpich/lib/ /usr/lib/libhdf5.so -lpthread -lz -lm
Making all in mbfacetgeom
make[5]: Entering directory `/disk/itaps-buildslave/moab-distcheck/build/moab-4.99/_build/tools/mbfacetgeom'
/bin/sh ../../libtool --tag=CXX --mode=compile g++ -DHAVE_CONFIG_H -I. -I../../../tools/mbfacetgeom -I../.. -I../../src/moab -I../../src/parallel -I../../src -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64 -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -DMESHDIR=../../../MeshFiles/unittest -I../../../src -I../../src -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT FBEngine.lo -MD -MP -MF .deps/FBEngine.Tpo -c -o FBEngine.lo ../../../tools/mbfacetgeom/FBEngine.cpp
g++ -DHAVE_CONFIG_H -I. -I../../../tools/mbfacetgeom -I../.. -I../../src/moab -I../../src/parallel -I../../src -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64 -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -DMESHDIR=../../../MeshFiles/unittest -I../../../src -I../../src -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT FBEngine.lo -MD -MP -MF .deps/FBEngine.Tpo -c ../../../tools/mbfacetgeom/FBEngine.cpp -o FBEngine.o
../../../tools/mbfacetgeom/FBEngine.cpp:14:27: error: SmoothCurve.hpp: No such file or directory
../../../tools/mbfacetgeom/FBEngine.cpp:15:26: error: SmoothFace.hpp: No such file or directory
../../../tools/mbfacetgeom/FBEngine.cpp: In destructor 'FBEngine::~FBEngine()':
../../../tools/mbfacetgeom/FBEngine.cpp:54: warning: possible problem detected in invocation of delete operator:
../../../tools/mbfacetgeom/FBEngine.cpp:54: warning: invalid use of incomplete type 'struct SmoothCurve'
../../../tools/mbfacetgeom/FBEngine.hpp:20: warning: forward declaration of 'struct SmoothCurve'
../../../tools/mbfacetgeom/FBEngine.cpp:54: note: neither the destructor nor the class-specific operator delete will be called, even if they are declared when the class is defined.
../../../tools/mbfacetgeom/FBEngine.cpp:59: warning: possible problem detected in invocation of delete operator:
../../../tools/mbfacetgeom/FBEngine.cpp:59: warning: invalid use of incomplete type 'struct SmoothFace'
../../../tools/mbfacetgeom/FBEngine.hpp:19: warning: forward declaration of 'struct SmoothFace'
../../../tools/mbfacetgeom/FBEngine.cpp:59: note: neither the destructor nor the class-specific operator delete will be called, even if they are declared when the class is defined.
../../../tools/mbfacetgeom/FBEngine.cpp: In member function 'moab::ErrorCode FBEngine::initializeSmoothing()':
../../../tools/mbfacetgeom/FBEngine.cpp:103: error: 'GEOM_DIMENSION_TAG_NAME' was not declared in this scope
../../../tools/mbfacetgeom/FBEngine.cpp:105: error: 'GLOBAL_ID_TAG_NAME' was not declared in this scope
../../../tools/mbfacetgeom/FBEngine.cpp:119: error: invalid use of incomplete type 'struct SmoothFace'
../../../tools/mbfacetgeom/FBEngine.hpp:19: error: forward declaration of 'struct SmoothFace'
../../../tools/mbfacetgeom/FBEngine.cpp:134: error: invalid use of incomplete type 'struct SmoothCurve'
../../../tools/mbfacetgeom/FBEngine.hpp:20: error: forward declaration of 'struct SmoothCurve'
../../../tools/mbfacetgeom/FBEngine.cpp:140: error: invalid use of incomplete type 'struct SmoothFace'
../../../tools/mbfacetgeom/FBEngine.cpp:141: error: invalid use of incomplete type 'struct SmoothFace'
../../../tools/mbfacetgeom/FBEngine.cpp:180: error: invalid use of incomplete type 'struct SmoothCurve'
../../../tools/mbfacetgeom/FBEngine.cpp:182: error: invalid use of incomplete type 'struct SmoothCurve'
../../../tools/mbfacetgeom/FBEngine.cpp:191: error: invalid use of incomplete type 'struct SmoothFace'
../../../tools/mbfacetgeom/FBEngine.cpp:199: error: invalid use of incomplete type 'struct SmoothFace'
../../../tools/mbfacetgeom/FBEngine.cpp:211: error: invalid use of incomplete type 'struct SmoothFace'
../../../tools/mbfacetgeom/FBEngine.cpp: In member function 'moab::ErrorCode FBEngine::getEntClosestPt(moab::EntityHandle, double, double, double, double*, double*, double*)':
../../../tools/mbfacetgeom/FBEngine.cpp:413: error: invalid use of incomplete type 'struct SmoothFace'
../../../tools/mbfacetgeom/FBEngine.cpp: In member function 'moab::ErrorCode FBEngine::getEntNrmlXYZ(moab::EntityHandle, double, double, double, double*, double*, double*)':
../../../tools/mbfacetgeom/FBEngine.cpp:504: error: invalid use of incomplete type 'struct SmoothFace'
../../../tools/mbfacetgeom/FBEngine.cpp: In member function 'moab::ErrorCode FBEngine::getPntRayIntsct(double, double, double, double, double, double, std::vector<long unsigned int, std::allocator<long unsigned int> >&, std::vector<double, std::allocator<double> >&, std::vector<double, std::allocator<double> >&)':
../../../tools/mbfacetgeom/FBEngine.cpp:595: warning: comparison between signed and unsigned integer expressions
../../../tools/mbfacetgeom/FBEngine.cpp:605: warning: comparison between signed and unsigned integer expressions
../../../tools/mbfacetgeom/FBEngine.cpp:619: error: invalid use of incomplete type 'struct SmoothFace'
sincerely,
-The Fathomatic
