[MOAB-dev] r4470 - in MOAB/trunk: . src src/moab tools/refiner tools/vtkMOABReader
tautges at mcs.anl.gov
Tue Jan 25 15:05:20 CST 2011
Author: tautges
Date: 2011-01-25 15:05:19 -0600 (Tue, 25 Jan 2011)
New Revision: 4470
Modified:
MOAB/trunk/configure.ac
MOAB/trunk/src/GeomTopoTool.cpp
MOAB/trunk/src/MBTagConventions.hpp
MOAB/trunk/src/moab/GeomTopoTool.hpp
MOAB/trunk/tools/refiner/Makefile.am
MOAB/trunk/tools/refiner/test_mesh_refiner.cpp
MOAB/trunk/tools/vtkMOABReader/vtkMOABReader.cxx
Log:
- Adding more functionality in GeomTopoTool
- Including parallel tags in MBTagConventions, sometimes we want these even from serial code
- more search paths for vtk
- a bit more testing of refiner
Modified: MOAB/trunk/configure.ac
--- MOAB/trunk/configure.ac 2011-01-25 19:33:28 UTC (rev 4469)
+++ MOAB/trunk/configure.ac 2011-01-25 21:05:19 UTC (rev 4470)
@@ -716,7 +716,7 @@
x?*)
VTK_LIB_DIR=
VTK_INC_DIR=
- for dir in ${WITH_VTK}/include/vtk ${VTK_DIR}/include/vtk/Rendering ${WITH_VTK}/include ${WITH_VTK}; do
+ for dir in ${WITH_VTK}/include/vtk ${VTK_DIR}/include/vtk/Rendering ${WITH_VTK}/include ${WITH_VTK}/include/paraview-* ${WITH_VTK}; do
if test "x" = "x$VTK_INC_DIR"; then
AC_CHECK_FILE([${dir}/vtkRenderer.h],[VTK_INC_DIR="-I$dir"])
fi
Modified: MOAB/trunk/src/GeomTopoTool.cpp
--- MOAB/trunk/src/GeomTopoTool.cpp 2011-01-25 19:33:28 UTC (rev 4469)
+++ MOAB/trunk/src/GeomTopoTool.cpp 2011-01-25 21:05:19 UTC (rev 4470)
@@ -31,489 +31,546 @@
// forward and reverse volumes, respectively. If a surface
// is non-manifold in a single volume, the same volume will
// be listed for both the forward and reverse slots.
-const char GEOM_SENSE_2_TAG_NAME[] = "GEOM_SENSE_2";
+ const char GEOM_SENSE_2_TAG_NAME[] = "GEOM_SENSE_2";
-const char GEOM_SENSE_N_ENTS_TAG_NAME[] = "GEOM_SENSE_N_ENTS";
-const char GEOM_SENSE_N_SENSES_TAG_NAME[] = "GEOM_SENSE_N_SENSES";
+ const char GEOM_SENSE_N_ENTS_TAG_NAME[] = "GEOM_SENSE_N_ENTS";
+ const char GEOM_SENSE_N_SENSES_TAG_NAME[] = "GEOM_SENSE_N_SENSES";
-GeomTopoTool::GeomTopoTool(Interface *impl, bool find_geoments)
- : mdbImpl(impl),
- sense2Tag(0),
- senseNEntsTag(0),
- senseNSensesTag(0),
- obbTree(impl),
- contiguous(true),
- oneVolRootSet(0)
- ErrorCode result = mdbImpl->tag_create(GEOM_DIMENSION_TAG_NAME, 4,
- MB_TAG_SPARSE, geomTag, NULL);
- if (MB_SUCCESS != result && MB_ALREADY_ALLOCATED != result) {
- std::cerr << "Error: Failed to create geometry dimension tag."
- << std::endl;
+ GeomTopoTool::GeomTopoTool(Interface *impl, bool find_geoments)
+ : mdbImpl(impl),
+ sense2Tag(0),
+ senseNEntsTag(0),
+ senseNSensesTag(0),
+ obbTree(impl),
