[MOAB-dev] r4463 - MOAB/trunk/src/io/mhdf/src
kraftche at cae.wisc.edu
Fri Jan 21 14:16:04 CST 2011
Author: kraftche
Date: 2011-01-21 14:16:03 -0600 (Fri, 21 Jan 2011)
New Revision: 4463
Modified:
MOAB/trunk/src/io/mhdf/src/file.c
Log:
Some versions of HDF5 library (e.g. 1.8.4p2) segfault if asked to open some
random non-hdf5 binary file. The normal work-around for this is to
call H5Fis_hdf5 to check the file type first. However, that call has
no option to open the file in parallel, causing hacks like prefixing
the filename with bglockless: in Blue Gene machines to fail the test.
As an incomplete compromise, only call H5Fis_hdf5 if compiled with
an HDF5 library w/out support for MPI-IO.
Modified: MOAB/trunk/src/io/mhdf/src/file.c
--- MOAB/trunk/src/io/mhdf/src/file.c 2011-01-21 20:13:06 UTC (rev 4462)
+++ MOAB/trunk/src/io/mhdf/src/file.c 2011-01-21 20:16:03 UTC (rev 4463)
@@ -290,12 +290,13 @@
/* Check if file is HDF5 */
/* Don't do this because it can't handle MPI-IO driver code that
- passes options via prefixes on the file name.
+ passes options via prefixes on the file name. */
+#ifndef HDF5_PARALLEL
if (H5Fis_hdf5( filename ) <= 0) {
mhdf_setFail( status, "%s: File is not HDF5", filename );
return NULL;
+#endif
/* Create struct to hold working data */
file_ptr = mhdf_alloc_FileHandle( 0, status );
