[MOAB-dev] r4428 - in MOAB/trunk/src: . parallel
kraftche at cae.wisc.edu
Tue Jan 11 10:14:37 CST 2011
Author: kraftche
Date: 2011-01-11 10:14:37 -0600 (Tue, 11 Jan 2011)
New Revision: 4428
Modified:
MOAB/trunk/src/FileOptions.cpp
MOAB/trunk/src/FileOptions.hpp
MOAB/trunk/src/parallel/ReadParallel.cpp
Log:
if PARALLEL=BCAST_DELETE, don't check that all reader options were valid for the non-IO processors because they never call into the actual reader
Modified: MOAB/trunk/src/FileOptions.cpp
--- MOAB/trunk/src/FileOptions.cpp 2011-01-11 16:13:41 UTC (rev 4427)
+++ MOAB/trunk/src/FileOptions.cpp 2011-01-11 16:14:37 UTC (rev 4428)
@@ -371,6 +371,12 @@
return std::find( mSeen.begin(), mSeen.end(), false ) == mSeen.end();
+void FileOptions::mark_all_seen() const
+ mSeen.clear();
+ mSeen.resize( mOptions.size(), true );
ErrorCode FileOptions::get_unseen_option( std::string& name ) const
std::vector<bool>::iterator i = std::find( mSeen.begin(), mSeen.end(), false );
Modified: MOAB/trunk/src/FileOptions.hpp
--- MOAB/trunk/src/FileOptions.hpp 2011-01-11 16:13:41 UTC (rev 4427)
+++ MOAB/trunk/src/FileOptions.hpp 2011-01-11 16:14:37 UTC (rev 4428)
@@ -201,6 +201,9 @@
/** Check if all options have been looked at */
bool all_seen() const;
+ /** Mark all options as seen. USed for non-root procs during bcast-delete read */
+ void mark_all_seen() const;
/** Get first unseen option */
ErrorCode get_unseen_option( std::string& value ) const;
Modified: MOAB/trunk/src/parallel/ReadParallel.cpp
--- MOAB/trunk/src/parallel/ReadParallel.cpp 2011-01-11 16:13:41 UTC (rev 4427)
+++ MOAB/trunk/src/parallel/ReadParallel.cpp 2011-01-11 16:14:37 UTC (rev 4428)
@@ -223,7 +223,7 @@
if (print_parallel) pa_vec.push_back(PA_PRINT_PARALLEL);
- return load_file(file_names, num_files, file_set, parallel_mode,
+ result = load_file(file_names, num_files, file_set, parallel_mode,
partition_tag_name,
partition_tag_vals, distrib,
partition_by_rank, pa_vec, opts,
@@ -231,6 +231,10 @@
reader_rank, cputime,
resolve_dim, shared_dim,
ghost_dim, bridge_dim, num_layers, addl_ents);
