[MOAB-dev] Q on initializing MOAB iMesh interface
Tim Tautges
tautges at mcs.anl.gov
Mon Jan 10 09:07:21 CST 2011
Hmm, good point. The singletons in CGM don't allow multiple of those to exist, but maybe with a C++ version of iGeom
multiple ones of those could; or, is this just another form of a multiplexer?
- tim
On 01/08/2011 03:08 PM, Iulian Grindeanu wrote:
> Hello,
> Yes, I think this would be better. It should continue to allow multiple iMesh instances.
> Also, iGeom implementation in MOAB should be changed in a similar way.
> Currently only one iGeom instance is possible; a similar class is needed, that contains the
> global variables defined in iGeom_MOAB.cpp, and a pointer to Core (or MBiMesh?)
> Thanks,
> Iulian
>> Hi all,
>> Currently in MOAB's iMesh implementation, the class structure looks
>> like:
>> class MBiMesh : public Core
>> It's done this way because the iMesh implementation needs to keep some
>> member data that Core doesn't need. However, it
>> also makes it impossible to construct an iMesh object from an existing
>> Core object. I'd like to change that. What I'd
>> like to do is change MBiMesh from "isA" to "hasA", i.e. to make
>> MBiMesh point to an Interface object. The MBiMesh
>> object would keep track of whether it constructed MOAB or was passed
>> one, so it would know whether it could destroy it
>> in iMesh_dtor. I'd also like to enable the Interface::query_interface
>> method to return an iMesh instance, consistent
>> with other interfaces it already handles. The net effect of all this
>> would that applications could gain access to an
>> iMesh interface on a transient basis, e.g. if they wanted to call a
>> service implemented in iMesh but not MOAB.
>> Does anybody see any problem with this approach, or think I should do
>> it differently?
>> - tim
>> "You will keep in perfect peace him whose mind is
>> steadfast, because he trusts in you." Isaiah 26:3
>> Tim Tautges Argonne National Laboratory
>> (tautges at mcs.anl.gov) (telecommuting from UW-Madison)
>> phone: (608) 263-8485 1500 Engineering Dr.
>> fax: (608) 263-4499 Madison, WI 53706
