[MOAB-dev] Q on initializing MOAB iMesh interface
Tim Tautges
tautges at mcs.anl.gov
Sat Jan 8 11:51:46 CST 2011
Hi all,
Currently in MOAB's iMesh implementation, the class structure looks like:
class MBiMesh : public Core
It's done this way because the iMesh implementation needs to keep some member data that Core doesn't need. However, it
also makes it impossible to construct an iMesh object from an existing Core object. I'd like to change that. What I'd
like to do is change MBiMesh from "isA" to "hasA", i.e. to make MBiMesh point to an Interface object. The MBiMesh
object would keep track of whether it constructed MOAB or was passed one, so it would know whether it could destroy it
in iMesh_dtor. I'd also like to enable the Interface::query_interface method to return an iMesh instance, consistent
with other interfaces it already handles. The net effect of all this would that applications could gain access to an
iMesh interface on a transient basis, e.g. if they wanted to call a service implemented in iMesh but not MOAB.
Does anybody see any problem with this approach, or think I should do it differently?
- tim
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
