[MOAB-dev] r4415 - MOAB/trunk/config
kraftche at cae.wisc.edu
Tue Jan 4 12:31:45 CST 2011
Author: kraftche
Date: 2011-01-04 12:31:44 -0600 (Tue, 04 Jan 2011)
New Revision: 4415
Modified:
MOAB/trunk/config/netcdf.m4
Log:
remove more C++ related stuff from netcdf configure and better support detecting static netcdf 4.x
Modified: MOAB/trunk/config/netcdf.m4
--- MOAB/trunk/config/netcdf.m4 2011-01-04 18:31:05 UTC (rev 4414)
+++ MOAB/trunk/config/netcdf.m4 2011-01-04 18:31:44 UTC (rev 4415)
@@ -38,15 +38,6 @@
HAVE_NETCDF=no
if test "xno" != "x$NETCDF_ARG"; then
HAVE_NETCDF=yes
- # Check for stream headers and set STRSTREAM_H_SPEC accordingly
- AC_LANG_PUSH([C++])
- AC_CHECK_HEADER( [strstream.h], [NETCDF_DEF="<strstream.h>"], [
- AC_CHECK_HEADER( [sstream.h], [NETCDF_DEF="<sstream.h>"], [
- AC_CHECK_HEADER( [strstream], [NETCDF_DEF="<strstream>"], [
- AC_CHECK_HEADER( [sstream], [NETCDF_DEF="<sstream>"] )
- AC_LANG_POP([C++])
# if a path is specified, update LIBS and INCLUDES accordingly
if test "xyes" != "x$NETCDF_ARG" && test "x" != "x$NETCDF_ARG"; then
@@ -91,43 +82,20 @@
[AC_MSG_RESULT([no]); NETCDF_SUFFICIENT_DIMS_VARS=no])
fi
- AC_MSG_CHECKING([for netcdf.h])
- HAVE_NETCDF_H=no
- AC_TRY_COMPILE(
-[#include "netcdf.h"], [], [HAVE_NETCDF_H=yes; NETCDF_DEF=], [
- AC_TRY_COMPILE(
-[#define STRSTREAM_H_SPEC $NETCDF_DEF
- #include "netcdf.h"], [], [HAVE_NETCDF_H=yes], [HAVE_NETCDF_H=no])])
- AC_MSG_RESULT([$HAVE_NETCDF_H])
- if test $HAVE_NETCDF_H != yes; then
- AC_MSG_WARN([NetCDF C header not found])
- HAVE_NETCDF=no
- fi
- if test "x$NETCDF_DEF" != "x"; then
- NETCDF_CPPFLAGS="$NETCDF_CPPFLAGS -DSTRSTREAM_H_SPEC=$NETCDF_DEF"
- CPPFLAGS="$CPPFLAGS -DSTRSTREAM_H_SPEC=$NETCDF_DEF"
- fi
- AC_MSG_CHECKING([[for netcdf library]])
- old_LIBS="$LIBS"
- LIBS="$LIBS -lnetcdf"
- AC_TRY_LINK(
- [#include <netcdf.h>], [int ncFile; nc_create("foo",NC_CLOBBER, &ncFile);],
- [AC_MSG_RESULT([yes]); NETCDF_LIBS="-lnetcdf"],
- [AC_MSG_RESULT([no]);
- AC_MSG_CHECKING([for netcdf library requiring HDF5-high-level])
- LIBS="$LIBS -lhdf5_hl $HDF5_LIBS"
- AC_TRY_LINK(
