[MOAB-dev] Unable import a ccm file
    Rajeev Jain
    jain at mcs.anl.gov
    Mon Jan  3 09:55:03 CST 2011
After revision 4328: merge new capability to directly access tag storage, I'm
unable to import a ccm file in STAR-CCM+, it use to work before.
MOAB reads and writes the .ccm file without any errors. I'm using MOAB with
libccmio-2.06.020 option; the configure line is -
./configure --with-cgm=/homes/jain/lib/CGM-acis
--prefix=/homes/jain/lib/MOAB-acis
--with-hdf5=/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/serial/gcc/ --enable-debug
--with-ccmio=/homes/jain/libccmio-2.06.020/linux/64
The attached 1.ccm file looks to be an HDF file (according to Chris Cc'd in this
email) that is created using mbconvert on a cub file.
The a mesh file has a cube with 100 hexes.   When I try to debug this file using
ccmdump i get:
ccmdump 1.ccm
"ADF 16: Internal error: Memory boundary tag bad."
ccmdump is unable to open the this .ccm file.
Happy New Year.
 Rajeev
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20110103/5add6b9f/attachment-0001.htm>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20110103/5add6b9f/attachment-0001.obj>
