[MOAB-dev] r4412 - MOAB/trunk
    Tim Tautges
    tautges at mcs.anl.gov
    Wed Dec 22 18:25:50 CST 2010
Thanks Jason, I know I kind of threw this in there quickly and imperfectly.
- tim
On 12/22/2010 05:06 PM, kraftche at cae.wisc.edu wrote:
> Author: kraftche
> Date: 2010-12-22 17:06:49 -0600 (Wed, 22 Dec 2010)
> New Revision: 4412
> Modified:
>     MOAB/trunk/configure.ac
> Log:
> Clean up VTK configuration:
> o Remove duplicate VTK detection logic (qvdual&  vtkMOABReader)
> o Make --enable-vtkMOABReader imply --with-vtk
> o Make --enable-qvdual imply --with-vtk
> o Make --with-vtk imply --enable-vtkMOABReader
> o Do not check for VTK unless --with-vtk is specified (or implied)
> o Check for VTK headers in additional default directories
> o Fail early if --with-vtk is specified (or implied) and not found
> o Remove bogus warnings about build failing if VTK is not found
>     when neither vtkMOABReader nor qvdual is going to be built
> Modified: MOAB/trunk/configure.ac
> --- MOAB/trunk/configure.ac	2010-12-22 21:52:09 UTC (rev 4411)
> +++ MOAB/trunk/configure.ac	2010-12-22 23:06:49 UTC (rev 4412)
> @@ -505,6 +505,26 @@
>                  esac] )
> +#                            Optional Libraries
> +AC_ARG_WITH([vtk],
> +  [AC_HELP_STRING([--with-vtk@<:@=DIR@:>@], [Enable VTK support, and specify VTK location])],
> +  [WITH_VTK=$withval
> +   DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --with-vtk=\"${withval}\""
> +  ],[WITH_VTK=])
> +VTKMOAB_DEFAULT=no
> +if test "x$WITH_VTK" != "xno" -a "x$WITH_VTK" != "x"; then
> +  VTKMOAB_DEFAULT=yes
> +fi
> +echo "WITH_VTK=$WITH_VTK"
> +echo "VTKMOAB_DEFAULT=$VTKMOAB_DEFAULT"
>   #                           Optional Tools
> @@ -539,7 +559,7 @@
>   MB_OPTIONAL_TOOL([mbconvert],    [yes])
>   MB_OPTIONAL_TOOL([hexmodops],    [yes])
>   MB_OPTIONAL_TOOL([qvdual],       [no] )
> -MB_OPTIONAL_TOOL([vtkMOABReader],[no] )
> +MB_OPTIONAL_TOOL([vtkMOABReader],[${VTKMOAB_DEFAULT}] )
>   MB_OPTIONAL_TOOL([mbsize],       [yes])
>   MB_OPTIONAL_TOOL([mbskin],       [yes])
>   MB_OPTIONAL_TOOL([mbtagprop],    [yes])
> @@ -560,7 +580,26 @@
>     fi
>   fi
> +if test "xyes" = "x$ENABLE_vtkMOABReader"; then
> +  if test "xno" == "x$WITH_VTK"; then
> +    AC_MSG_ERROR([vtkMOABReader requires VTK])
> +  elif test "x" == "x$WITH_VTK"; then
> +    WITH_VTK=yes
> +  fi
> +fi
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
