[MOAB-dev] r4402 - MOAB/trunk/test
kraftche at cae.wisc.edu kraftche at cae.wisc.edu
Tue Dec 21 16:37:26 CST 2010
Author: kraftche
Date: 2010-12-21 16:37:26 -0600 (Tue, 21 Dec 2010)
New Revision: 4402
Modified:
   MOAB/trunk/test/CMakeLists.txt
Log:
fix cmake build of moab_test and add cmake build of tag_test
Modified: MOAB/trunk/test/CMakeLists.txt
--- MOAB/trunk/test/CMakeLists.txt	2010-12-21 22:37:07 UTC (rev 4401)
+++ MOAB/trunk/test/CMakeLists.txt	2010-12-21 22:37:26 UTC (rev 4402)
@@ -9,11 +9,15 @@
   add_executable( moab_test MBTest.cpp )
   target_link_libraries( moab_test MOAB )
-  set_source_files_properties( scdseq_test.cpp
+  set_source_files_properties( mBTest.cpp
     COMPILE_FLAGS "-DSRCDIR=${CMAKE_CURRENT_SOURCE_DIR}" )
   add_test( TestMOAB ${EXECUTABLE_OUTPUT_PATH}/moab_test -nostress )
   # FIXME: moab_test depends on: test/mb_big_test.g test/cell1.gen test/cell2.gen
+  add_executable( tag_test TagTest.cpp )
+  target_link_libraries( tag_test MOAB )
+  add_test( TagTest ${EXECUTABLE_OUTPUT_PATH}/tag_test )
   add_executable( seq_man_test TestTypeSequenceManager.cpp )
   target_link_libraries( seq_man_test MOAB )
   set_source_files_properties( TestTypeSequenceManager.cpp
