[MOAB-dev] r4398 - in MOAB/trunk: src src/io src/moab test
    kraftche at cae.wisc.edu
    Tue Dec 21 16:16:20 CST 2010
Author: kraftche
Date: 2010-12-21 16:16:20 -0600 (Tue, 21 Dec 2010)
New Revision: 4398
Added:
   MOAB/trunk/src/BitPage.cpp
   MOAB/trunk/src/BitPage.hpp
   MOAB/trunk/src/BitTag.cpp
   MOAB/trunk/src/BitTag.hpp
   MOAB/trunk/src/DenseTag.cpp
   MOAB/trunk/src/DenseTag.hpp
   MOAB/trunk/src/MeshTag.cpp
   MOAB/trunk/src/MeshTag.hpp
   MOAB/trunk/src/SparseTag.cpp
   MOAB/trunk/src/SparseTag.hpp
   MOAB/trunk/src/VarLenDenseTag.cpp
   MOAB/trunk/src/VarLenDenseTag.hpp
   MOAB/trunk/src/VarLenSparseTag.cpp
   MOAB/trunk/src/VarLenSparseTag.hpp
Removed:
   MOAB/trunk/src/BitTagServer.cpp
   MOAB/trunk/src/BitTagServer.hpp
   MOAB/trunk/src/SparseTagCollection.cpp
   MOAB/trunk/src/SparseTagCollection.hpp
   MOAB/trunk/src/TagServer.cpp
   MOAB/trunk/src/TagServer.hpp
Modified:
   MOAB/trunk/src/Core.cpp
   MOAB/trunk/src/HigherOrderFactory.cpp
   MOAB/trunk/src/Internals.hpp
   MOAB/trunk/src/Makefile.am
   MOAB/trunk/src/SequenceData.cpp
   MOAB/trunk/src/SequenceData.hpp
   MOAB/trunk/src/SequenceManager.cpp
   MOAB/trunk/src/SequenceManager.hpp
   MOAB/trunk/src/TagCompare.hpp
   MOAB/trunk/src/TagInfo.cpp
   MOAB/trunk/src/TagInfo.hpp
   MOAB/trunk/src/TypeSequenceManager.cpp
   MOAB/trunk/src/TypeSequenceManager.hpp
   MOAB/trunk/src/VarLenTag.hpp
   MOAB/trunk/src/WriteUtil.cpp
   MOAB/trunk/src/io/ReadHDF5.cpp
   MOAB/trunk/src/io/WriteHDF5.cpp
   MOAB/trunk/src/moab/Core.hpp
   MOAB/trunk/src/moab/Interface.hpp
   MOAB/trunk/src/moab/Types.hpp
   MOAB/trunk/test/TagTest.cpp
   MOAB/trunk/test/TestTypeSequenceManager.cpp
Log:
reorganize tag storage
Copied: MOAB/trunk/src/BitPage.cpp (from rev 4369, MOAB/trunk/src/BitTagServer.cpp)
--- MOAB/trunk/src/BitPage.cpp	                        (rev 0)
+++ MOAB/trunk/src/BitPage.cpp	2010-12-21 22:16:20 UTC (rev 4398)
@@ -0,0 +1,37 @@
+#include "BitPage.hpp"
+#include "moab/Range.hpp"
+#include <stdlib.h>
+#include <string.h>
+namespace moab {
+void BitPage::search( unsigned char value, int offset, int count,
+                      int per_ent, Range& results, EntityHandle start ) const
+  const int end = offset + count;
+  Range::iterator hint = results.begin();
+  while (offset != end) {
+    if (get_bits( offset, per_ent ) == value)
+      hint = results.insert( hint, start );
+    ++offset;
+    ++start;
+BitPage::BitPage( int per_ent, unsigned char init_val )
+  unsigned char mask = (1<<per_ent)-1; // 2^per_ent - 1
+  init_val &= mask;
+  switch (per_ent) {
+    default: assert(false); abort(); break; // must be power of two
+      // Note: no breaks. fall through such that all bits in init_val are set
+    case 1: init_val |= (init_val << 1);
+    case 2: init_val |= (init_val << 2);
+    case 4: init_val |= (init_val << 4);
+    case 8: ;
+  memset( byteArray, init_val, BitTag::PageSize );
+} // namespace moab
Copied: MOAB/trunk/src/BitPage.hpp (from rev 4369, MOAB/trunk/src/BitTagServer.hpp)
--- MOAB/trunk/src/BitPage.hpp	                        (rev 0)
+++ MOAB/trunk/src/BitPage.hpp	2010-12-21 22:16:20 UTC (rev 4398)
@@ -0,0 +1,172 @@
+#ifndef BIT_PAGE_HPP
+#define BIT_PAGE_HPP
