[MOAB-dev] r4395 - in MOAB/trunk: src tools/dagmc
    bmsmith6 at wisc.edu
    Tue Dec 21 13:50:05 CST 2010
Author: bmsmith
Date: 2010-12-21 13:50:05 -0600 (Tue, 21 Dec 2010)
New Revision: 4395
Modified:
   MOAB/trunk/src/OrientedBoxTreeTool.cpp
   MOAB/trunk/tools/dagmc/test_geom.cc
Log:
-bug fix: affected DAGMC point_in_volume only if ray trajectory intersected an edge
or node AND overlaps were assumed to exist (0 != overlap_thickness). Fixed by improving
the neighborhood handling for this type of call to ray_intersect_sets.
-added DAGMC test case for this failure mode.
Modified: MOAB/trunk/src/OrientedBoxTreeTool.cpp
--- MOAB/trunk/src/OrientedBoxTreeTool.cpp	2010-12-21 17:09:28 UTC (rev 4394)
+++ MOAB/trunk/src/OrientedBoxTreeTool.cpp	2010-12-21 19:50:05 UTC (rev 4395)
@@ -45,9 +45,10 @@
  *\param tri           The intersected triangle
  *\param ray_direction The direction of the ray
  *\param int_type      The type of intersection (EDGE0, EDGE1, NODE2, ...)
- *\param close_tris    Vector of triangles in the neighborhood of the intersection
- *\param close_senses  Vector of surface senses for tris in the neighborhood of
- *                     the intersection
+ *\param close_tris    Vector of triangles in the proximity of the intersection
+ *\param close_senses  Vector of surface senses for tris in the proximity of
+ *                     the intersection
+ *\param neighborhood  Vector of triangles in the topological neighborhood of the intersection
  *\return              True if piercing, false otherwise.
 static
@@ -56,7 +57,8 @@
                          const GeomUtil::intersection_type int_type,
                          const std::vector<EntityHandle>&  close_tris,
                          const std::vector<int>&           close_senses,
-                         const Interface*                  MBI ) {
+                         const Interface*                  MBI,
+                         std::vector<EntityHandle>*        neighborhood_tris = 0 ) {
   // get the node of the triangle
   const EntityHandle* conn;
@@ -137,6 +139,10 @@
     return MB_FAILURE;
+  // The close tris were in proximity to the intersection. The adj_tris are
+  // topologically adjacent to the intersection (the neighborhood).
+  if(neighborhood_tris) (*neighborhood_tris).assign( adj_tris.begin(), adj_tris.end() );
   // determine glancing/piercing
   // If a desired_orientation was used in this call to ray_intersect_sets,
   // the plucker_ray_tri_intersect will have already used it. For a piercing
@@ -164,7 +170,7 @@
     // intersection is glancing if tri and ray do not point in same direction
     // for every triangle
-    if(0!=sign && 0>sign*norm%ray_direction) return false;
+    if(0!=sign && 0>sign*dot_prod) return false;
   return true;
@@ -1011,6 +1017,8 @@
     unsigned int*        raytri_test_count;
     EntityHandle         lastSet;
