[MOAB-dev] buildbot failure in Fathom on moab-distcheck
    moab-dev at mcs.anl.gov
    Mon Dec 20 00:11:30 CST 2010
The Fathomatic has detected a failed build of moab-distcheck on Fathom.
Full details are available at:
 http://gnep.mcs.anl.gov:8010/builders/moab-distcheck/builds/355
Buildbot URL: http://gnep.mcs.anl.gov:8010/
Buildslave for this Build: gnep
Build Reason: The Nightly scheduler named 'nightly' triggered this build
Build Source Stamp: None
Blamelist:
BUILD FAILED: failed compile
LOG EXCERPT:
make[1]: Entering directory `/disk/itaps-buildslave/moab-distcheck/build'
{ test ! -d moab-4.99 || { find moab-4.99 -type d ! -perm -200 -exec chmod u+w {} ';' && rm -fr moab-4.99; }; }
test -d moab-4.99 || mkdir moab-4.99
list='src MeshFiles itaps tools test doc examples'; for subdir in $list; do \
	  if test "$subdir" = .; then :; else \
	    test -d "moab-4.99/$subdir" \
	    || /bin/mkdir -p "moab-4.99/$subdir" \
	    || exit 1; \
	    distdir=`CDPATH="${ZSH_VERSION+.}:" && cd moab-4.99 && pwd`; \
	    top_distdir=`CDPATH="${ZSH_VERSION+.}:" && cd moab-4.99 && pwd`; \
	    (cd $subdir && \
	      make  \
	        top_distdir="$top_distdir" \
	        distdir="$distdir/$subdir" \
		am__remove_distdir=: \
		am__skip_length_check=: \
	        distdir) \
	      || exit 1; \
	  fi; \
	done
make[2]: Entering directory `/disk/itaps-buildslave/moab-distcheck/build/src'
cd .. && /bin/sh /disk/itaps-buildslave/moab-distcheck/build/config/missing --run autoheader
rm -f stamp-h5
touch FCDefs.h.in
cd .. && /bin/sh ./config.status src/FCDefs.h
config.status: creating src/FCDefs.h
config.status: src/FCDefs.h is unchanged
make[2]: *** No rule to make target `ScdInterface.hpp', needed by `distdir'.  Stop.
sincerely,
 -The Fathomatic
