[MOAB-dev] buildbot failure in Fathom on moab-doc
moab-dev at mcs.anl.gov moab-dev at mcs.anl.gov
Sat Dec 18 00:02:35 CST 2010
The Fathomatic has detected a failed build of moab-doc on Fathom.
Full details are available at:
 http://gnep.mcs.anl.gov:8010/builders/moab-doc/builds/251
Buildbot URL: http://gnep.mcs.anl.gov:8010/
Buildslave for this Build: gnep
Build Reason: The Nightly scheduler named 'nightly' triggered this build
Build Source Stamp: None
Blamelist:
BUILD FAILED: failed configure
LOG EXCERPT:
checking for main in -lvtkfreetype... no
checking for main in -lvtkexpat... no
checking for main in -lvtkzlib... no
checking for main in -lvtkpng... no
checking for main in -lvtkjpeg... no
checking for main in -lvtktiff... no
checking for main in -lvtkftgl... no
checking for main in -lvtkFiltering... no
checking for main in -lvtkImaging... no
checking for main in -lverdict... no
checking for main in -lvtkGraphics... no
checking for main in -lvtkNetCDF... no
checking for main in -lvtkexoIIc... no
checking for main in -lvtkmetaio... no
checking for main in -lvtkIO... no
checking for main in -lvtkRendering... no
checking for main in -lvtkParallel... no
checking for main in -lvtkHybrid... no
checking for main in -lQVTK... no
configure: WARNING: "VTK library 'vtkCommon' not found."
configure: WARNING: "VTK library 'vtkRendering' not found."
configure: creating ./config.status
config.status: creating Makefile
config.status: creating moab.make
config.status: creating src/Makefile
config.status: creating src/io/Makefile
config.status: creating src/io/mhdf/Makefile
config.status: creating src/parallel/Makefile
config.status: creating src/oldinc/Makefile
config.status: creating test/Makefile
config.status: creating test/h5file/Makefile
config.status: creating test/dual/Makefile
config.status: creating test/obb/Makefile
config.status: creating test/perf/Makefile
config.status: creating test/io/Makefile
config.status: creating test/parallel/Makefile
config.status: creating test/oldinc/Makefile
config.status: creating itaps/Makefile
config.status: creating itaps/imesh/Makefile
config.status: creating itaps/imesh/iMesh-Defs.inc
config.status: creating itaps/igeom/Makefile
config.status: creating itaps/igeom/iGeom-Defs.inc
config.status: creating tools/Makefile
config.status: creating tools/refiner/Makefile
config.status: creating tools/mbcoupler/Makefile
config.status: creating tools/mbzoltan/Config.moab
config.status: creating tools/mbzoltan/Makefile
config.status: creating tools/mcnpmit/Makefile
config.status: creating tools/qvdual/Makefile
config.status: error: cannot find input file: tools/vtkMOABReader/Makefile.in
sincerely,
 -The Fathomatic
