[MOAB-dev] r4383 - in MOAB/trunk: . src src/io test tools tools/vtkMOABReader
tautges at mcs.anl.gov
Fri Dec 17 17:03:47 CST 2010
Author: tautges
Date: 2010-12-17 17:03:47 -0600 (Fri, 17 Dec 2010)
New Revision: 4383
Modified:
MOAB/trunk/configure.ac
MOAB/trunk/src/Core.cpp
MOAB/trunk/src/Makefile.am
MOAB/trunk/src/io/ReadNC.cpp
MOAB/trunk/test/scdseq_test.cpp
MOAB/trunk/tools/Makefile.am
MOAB/trunk/tools/vtkMOABReader/vtkMOABReader.cxx
MOAB/trunk/tools/vtkMOABReader/vtkMOABReader.h
Log:
Introducing a new structured mesh interface to MOAB. The primary means to using this interface
is through the ScdInterface and ScdBox classes, declared in moab/ScdInterface.hpp. One gets
an instance of this interface through the Interface::query_interface function, using
"ScdInterface" for the interface name (destruction of the interface is through the release_interface
method).
See the ScdInterface.hpp header for a general description of the structured mesh interface.
I'm also including a few assorted changes to the tools/vtkMOABReader tool, though these don't build
properly yet, but that tool is off by default, so this shouldn't affect anybody.
Passes make check, including a completely rewritten scdseq_test.
Modified: MOAB/trunk/configure.ac
--- MOAB/trunk/configure.ac 2010-12-17 15:49:43 UTC (rev 4382)
+++ MOAB/trunk/configure.ac 2010-12-17 23:03:47 UTC (rev 4383)
@@ -539,6 +539,7 @@
MB_OPTIONAL_TOOL([mbconvert], [yes])
MB_OPTIONAL_TOOL([hexmodops], [yes])
MB_OPTIONAL_TOOL([qvdual], [no] )
+MB_OPTIONAL_TOOL([vtkMOABReader],[no] )
MB_OPTIONAL_TOOL([mbsize], [yes])
MB_OPTIONAL_TOOL([mbskin], [yes])
MB_OPTIONAL_TOOL([mbtagprop], [yes])
@@ -748,7 +749,7 @@
xyes|x)
VTK_LIB_DIR=
VTK_INC_DIR=
- for dir in /usr/include/vtk /usr/local/include/vtk /include/vtk /usr/include/vtk-5.0; do
+ for dir in /usr/include/vtk /usr/local/include/vtk /include/vtk /usr/include/vtk-5.0 /usr/include/vtk-5.2; do
if test "x" = "x$VTK_INC_DIR"; then
AC_CHECK_FILE([${dir}/vtkRenderer.h],[VTK_INC_DIR="-I$dir"])
fi
@@ -972,6 +973,192 @@
fi
+# X
+AC_PATH_X
+AC_PATH_XTRA
+if test "xyes" = "x$no_x"; then
+ X_MISSING=yes
+fi
+# VTK
+ AC_LANG_SAVE
+ AC_LANG_CPLUSPLUS
+ AC_ARG_WITH([vtk],
+ [AC_HELP_STRING([--with-vtk=DIR], [Specify directory containing VTK])],
+ [VTK_DIR=$withval
+ DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --with-vtk=\"${withval}\""
+ ],[VTK_DIR=])
+ VTK_INCLUDES=
+ case "x$VTK_DIR" in
+ xno)
+ VTK_MISSING=yes
