[MOAB-dev] buildbot failure in Fathom on moab-distcheck
moab-dev at mcs.anl.gov
Thu Dec 16 00:11:19 CST 2010
The Fathomatic has detected a failed build of moab-distcheck on Fathom.
Full details are available at:
http://gnep.mcs.anl.gov:8010/builders/moab-distcheck/builds/351
Buildbot URL: http://gnep.mcs.anl.gov:8010/
Buildslave for this Build: gnep
Build Reason: The Nightly scheduler named 'nightly' triggered this build
Build Source Stamp: None
Blamelist:
BUILD FAILED: failed compile
LOG EXCERPT:
(cd $subdir && \
make \
top_distdir="$top_distdir" \
distdir="$distdir/$subdir" \
am__remove_distdir=: \
am__skip_length_check=: \
distdir) \
|| exit 1; \
fi; \
done
make[4]: Entering directory `/disk/itaps-buildslave/moab-distcheck/build/src/io/mhdf'
make[3]: Entering directory `/disk/itaps-buildslave/moab-distcheck/build/src/oldinc'
make[2]: Entering directory `/disk/itaps-buildslave/moab-distcheck/build/MeshFiles'
list='unittest'; for subdir in $list; do \
if test "$subdir" = .; then :; else \
test -d "/disk/itaps-buildslave/moab-distcheck/build/moab-4.99/MeshFiles/$subdir" \
|| /bin/mkdir -p "/disk/itaps-buildslave/moab-distcheck/build/moab-4.99/MeshFiles/$subdir" \
|| exit 1; \
distdir=`CDPATH="${ZSH_VERSION+.}:" && cd /disk/itaps-buildslave/moab-distcheck/build/moab-4.99/MeshFiles && pwd`; \
top_distdir=`CDPATH="${ZSH_VERSION+.}:" && cd /disk/itaps-buildslave/moab-distcheck/build/moab-4.99 && pwd`; \
(cd $subdir && \
make \
distdir) \
|| exit 1; \
fi; \
done
make[3]: Entering directory `/disk/itaps-buildslave/moab-distcheck/build/MeshFiles/unittest'
list='io'; for subdir in $list; do \
test -d "/disk/itaps-buildslave/moab-distcheck/build/moab-4.99/MeshFiles/unittest/$subdir" \
|| /bin/mkdir -p "/disk/itaps-buildslave/moab-distcheck/build/moab-4.99/MeshFiles/unittest/$subdir" \
|| exit 1; \
distdir=`CDPATH="${ZSH_VERSION+.}:" && cd /disk/itaps-buildslave/moab-distcheck/build/moab-4.99/MeshFiles/unittest && pwd`; \
(cd $subdir && \
make \
distdir) \
|| exit 1; \
fi; \
done
make[4]: Entering directory `/disk/itaps-buildslave/moab-distcheck/build/MeshFiles/unittest/io'
make[4]: *** No rule to make target `dum.sat', needed by `distdir'. Stop.
sincerely,
-The Fathomatic
