[MOAB-dev] r4375 - MOAB/trunk/src/io
    tautges at mcs.anl.gov
    Tue Dec 14 22:19:56 CST 2010
Author: tautges
Date: 2010-12-14 22:19:55 -0600 (Tue, 14 Dec 2010)
New Revision: 4375
Modified:
   MOAB/trunk/src/io/ReadNC.cpp
   MOAB/trunk/src/io/ReadNC.hpp
Log:
Sigh; need ptrdiff_t instead of size_t for one of the arg types.
Modified: MOAB/trunk/src/io/ReadNC.cpp
--- MOAB/trunk/src/io/ReadNC.cpp	2010-12-15 02:38:54 UTC (rev 4374)
+++ MOAB/trunk/src/io/ReadNC.cpp	2010-12-15 04:19:55 UTC (rev 4375)
@@ -608,6 +608,7 @@
   klMin = kMin; klMax = kMax;
     // parse options to get subset
+#ifdef USE_MPI
   if (isParallel) {
       // partition *the elements* over the parametric space; 1d partition for now, in the k parameter
       // (or j if there isn't one)
@@ -631,6 +632,7 @@
       ilMin = iMin; ilMax = iMax;
+#endif
   opts.get_int_option("IMIN", ilMin);
   opts.get_int_option("IMAX", ilMax);
@@ -708,7 +710,7 @@
     // check to make sure it's a float or double
   int fail;
   NCDF_SIZE tmin = lmin, tcount = lmax - lmin + 1;
-  NCDF_SIZE dum_stride = 1;
+  NCDF_DIFF dum_stride = 1;
   if (NC_DOUBLE == (*vmit).second.varDataType) {
     cvals.resize(tcount);
     fail = NCFUNCA(get_vars_double)(fileId, (*vmit).second.varId, &tmin, &tcount, &dum_stride, &cvals[0]);
Modified: MOAB/trunk/src/io/ReadNC.hpp
--- MOAB/trunk/src/io/ReadNC.hpp	2010-12-15 02:38:54 UTC (rev 4374)
+++ MOAB/trunk/src/io/ReadNC.hpp	2010-12-15 04:19:55 UTC (rev 4375)
@@ -32,11 +32,13 @@
 #  define NCFUNC(func) ncmpi_ ## func
 #  define NCFUNCA(func) ncmpi_ ## func ## _all
 #  define NCDF_SIZE MPI_Offset
+#  define NCDF_DIFF MPI_Offset
 #else
 #  include "netcdf.h"
 #  define NCFUNC(func) nc_ ## func
 #  define NCFUNCA(func) nc_ ## func
 #  define NCDF_SIZE size_t
+#  define NCDF_DIFF ptrdiff_t
 #endif
 namespace moab {
