[MOAB-dev] r4317 - in MOAB/trunk: src src/io test/io
    Steve Jackson
    sjackson at cae.wisc.edu
    Mon Dec 13 13:20:58 CST 2010
A fresh build of MOAB is not passing make check for me right now, and it seems to be related to the commit described below.  read_cgm_test.cpp wants to find an input called dum.sat, which is missing.
~S
On Dec 3, 2010, at 12:09 , tautges at mcs.anl.gov wrote:
> Author: tautges
> Date: 2010-12-03 12:09:10 -0600 (Fri, 03 Dec 2010)
> New Revision: 4317
> Added:
>   MOAB/trunk/test/io/read_cgm_test.cpp
> Modified:
>   MOAB/trunk/src/GeomTopoTool.cpp
>   MOAB/trunk/src/io/ReadCGM.cpp
>   MOAB/trunk/test/io/Makefile.am
> Log:
> Removed the deinitialize of CGM from ~ReadCGM.  Still not entirely satisfied
> with this, since it leaves CGM initialized, but don't have a good long-term
> solution yet.
> Also fix a few places in GeomTopoTool that couldn't handle tags already created,
> and added a cgm reader test that tests multiple reads.
> Passes make check.
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20101213/eae15b65/attachment.htm>
