[MOAB-dev] r4350 - MOAB/trunk/config
    Tim Tautges
    tautges at mcs.anl.gov
    Fri Dec 10 12:26:07 CST 2010
So, I've completely removed our dependence on the C++ netcdf functions.  I *think* I've tested thoroughly, but there's a
good chance that I've broken something that isn't indicated in my environment.  So, please build a trunk version of the
repo, and let me know if you see any problems.  Thanks.
- tim
On 12/10/2010 12:20 PM, tautges at mcs.anl.gov wrote:
> Author: tautges
> Date: 2010-12-10 12:20:01 -0600 (Fri, 10 Dec 2010)
> New Revision: 4350
> Modified:
>     MOAB/trunk/config/netcdf.m4
> Log:
> Removing support for C++ netcdf library.
> Modified: MOAB/trunk/config/netcdf.m4
> --- MOAB/trunk/config/netcdf.m4	2010-12-10 18:07:00 UTC (rev 4349)
> +++ MOAB/trunk/config/netcdf.m4	2010-12-10 18:20:01 UTC (rev 4350)
> @@ -1,5 +1,5 @@
> -# Check for NetCDF library ((C++)
> +# Check for NetCDF library
>   # Sets HAVE_NETCDF to 'yes' or 'no'
>   # If HAVE_NETCDF == yes, then exports:
>   #   NETCDF_CPPFLAGS
> @@ -91,39 +91,38 @@
>         [AC_MSG_RESULT([no]); NETCDF_SUFFICIENT_DIMS_VARS=no])
>     fi
> -  AC_MSG_CHECKING([for netcdf.hh])
> -  AC_LANG_PUSH([C++])
> -  HAVE_NETCDF_HH=no
> +  AC_MSG_CHECKING([for netcdf.h])
> +  HAVE_NETCDF_H=no
>     AC_TRY_COMPILE(
> -[#include "netcdf.hh"], [], [HAVE_NETCDF_HH=yes; NETCDF_DEF=], [
> +[#include "netcdf.h"], [], [HAVE_NETCDF_H=yes; NETCDF_DEF=], [
>       AC_TRY_COMPILE(
>   [#define STRSTREAM_H_SPEC $NETCDF_DEF
> - #include "netcdf.hh"], [], [HAVE_NETCDF_HH=yes], [NAVE_NETCDF_HH=no])])
> -  AC_MSG_RESULT([$HAVE_NETCDF_HH])
> -  if test $HAVE_NETCDF_HH != yes; then
> -    AC_MSG_WARN([NetCDF C++ header not found])
> + #include "netcdf.h"], [], [HAVE_NETCDF_H=yes], [HAVE_NETCDF_H=no])])
> +  AC_MSG_RESULT([$HAVE_NETCDF_H])
> +  if test $HAVE_NETCDF_H != yes; then
> +    AC_MSG_WARN([NetCDF C header not found])
>       HAVE_NETCDF=no
>     fi
>     if test "x$NETCDF_DEF" != "x"; then
>       NETCDF_CPPFLAGS="$NETCDF_CPPFLAGS -DSTRSTREAM_H_SPEC=$NETCDF_DEF"
>       CPPFLAGS="$CPPFLAGS -DSTRSTREAM_H_SPEC=$NETCDF_DEF"
>     fi
> -  AC_MSG_CHECKING([[for netcdf_c++ library]])
> +  AC_MSG_CHECKING([[for netcdf library]])
>     old_LIBS="$LIBS"
> -  LIBS="$LIBS -lnetcdf_c++ -lnetcdf"
> +  LIBS="$LIBS -lnetcdf"
>     AC_TRY_LINK(
> -    [#include<netcdf.hh>], [NcFile ncf("foo",NcFile::ReadOnly);],
> -    [AC_MSG_RESULT([yes]); NETCDF_LIBS="-lnetcdf_c++ -lnetcdf"],
> +    [#include<netcdf.h>], [int ncFile; nc_create("foo",NC_CLOBBER,&ncFile);],
> +    [AC_MSG_RESULT([yes]); NETCDF_LIBS="-lnetcdf"],
> -     AC_MSG_CHECKING([for netcdf_c++ library requiring HDF5-high-level])
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
