[MOAB-dev] r4343 - in MOAB/trunk: src src/io/mhdf/src tools/refiner
    kraftche at cae.wisc.edu
    Thu Dec  9 14:24:25 CST 2010
Author: kraftche
Date: 2010-12-09 14:24:25 -0600 (Thu, 09 Dec 2010)
New Revision: 4343
Modified:
   MOAB/trunk/src/Core.cpp
   MOAB/trunk/src/io/mhdf/src/file.c
   MOAB/trunk/src/io/mhdf/src/tags.c
   MOAB/trunk/tools/refiner/MeshOutputFunctor.cpp
   MOAB/trunk/tools/refiner/RefinerTagManager.cpp
   MOAB/trunk/tools/refiner/SplitVertices.cpp
Log:
fix warnings
Modified: MOAB/trunk/src/Core.cpp
--- MOAB/trunk/src/Core.cpp	2010-12-09 19:41:48 UTC (rev 4342)
+++ MOAB/trunk/src/Core.cpp	2010-12-09 20:24:25 UTC (rev 4343)
@@ -168,7 +168,7 @@
     writeMPELog = ! MPE_Initialized_logging();
     if (writeMPELog)
-      MPE_Init_log();
+      (void)MPE_Init_log();
 #endif
Modified: MOAB/trunk/src/io/mhdf/src/file.c
--- MOAB/trunk/src/io/mhdf/src/file.c	2010-12-09 19:41:48 UTC (rev 4342)
+++ MOAB/trunk/src/io/mhdf/src/file.c	2010-12-09 20:24:25 UTC (rev 4343)
@@ -393,6 +393,7 @@
                        mhdf_Status* status )
   FileHandle* file_ptr;
+  int result;
   API_BEGIN;
   file_ptr = (FileHandle*)(handle);
@@ -401,7 +402,7 @@
   /* Check for open handles.  HDF5 will not actually close the
      file until all handles are closed. */
-  int result = H5Fget_obj_count( file_ptr->hdf_handle, H5F_OBJ_ALL );
+  result = H5Fget_obj_count( file_ptr->hdf_handle, H5F_OBJ_ALL );
   if (result != 1)
     mhdf_setFail( status, "Cannot close file with open handles: "
Modified: MOAB/trunk/src/io/mhdf/src/tags.c
--- MOAB/trunk/src/io/mhdf/src/tags.c	2010-12-09 19:41:48 UTC (rev 4342)
+++ MOAB/trunk/src/io/mhdf/src/tags.c	2010-12-09 20:24:25 UTC (rev 4343)
@@ -563,10 +563,10 @@
                      const char* tag_name,
-  API_BEGIN;
   hid_t result;
   char* path;
+  API_BEGIN;
     /* Validate input */
