[MOAB-dev] r4313 - MOAB/trunk/itaps/imesh
jvporter at wisc.edu
Thu Dec 2 18:21:10 CST 2010
Author: jvporter
Date: 2010-12-02 18:21:10 -0600 (Thu, 02 Dec 2010)
New Revision: 4313
Modified:
MOAB/trunk/itaps/imesh/iMesh_MOAB.cpp
Log:
Partially fix iMesh_getEnt(Arr)2ndAdj:
* Accepts iBase_ALL_TYPES
* Returns iBase_INVALID_ARGUMENT if bridge and requested types are the same
Modified: MOAB/trunk/itaps/imesh/iMesh_MOAB.cpp
--- MOAB/trunk/itaps/imesh/iMesh_MOAB.cpp 2010-12-02 21:45:52 UTC (rev 4312)
+++ MOAB/trunk/itaps/imesh/iMesh_MOAB.cpp 2010-12-03 00:21:10 UTC (rev 4313)
@@ -765,7 +765,7 @@
void iMesh_getEntArr2ndAdj( iMesh_Instance instance,
iBase_EntityHandle const* entity_handles,
int entity_handles_size,
- int order_adjacent_key,
+ int bridge_entity_type,
int requested_entity_type,
iBase_EntityHandle** adj_entity_handles,
int* adj_entity_handles_allocated,
@@ -777,8 +777,8 @@
ErrorCode result = MB_SUCCESS;
- ALLOC_CHECK_ARRAY(offset, entity_handles_size+1 );
+ ALLOC_CHECK_ARRAY(offset, entity_handles_size+1);
const EntityHandle* entity_iter = (const EntityHandle*)entity_handles;
const EntityHandle* const entity_end = entity_iter + entity_handles_size;
int* off_iter = *offset;
@@ -787,16 +787,32 @@
std::vector<EntityHandle> all_adj_ents;
MeshTopoUtil mtu(MBI);
+ int min_bridge = iBase_VERTEX, max_bridge = iBase_REGION;
+ int min_req = iBase_VERTEX, max_req = iBase_REGION;
+ if (iBase_ALL_TYPES != bridge_entity_type)
+ min_bridge = max_bridge = bridge_entity_type;
+ if (iBase_ALL_TYPES != requested_entity_type)
+ min_req = max_req = requested_entity_type;
for ( ; entity_iter != entity_end; ++entity_iter)
*off_iter = prev_off;
off_iter++;
Range adj_ents;
- result = mtu.get_bridge_adjacencies( *entity_iter,
- order_adjacent_key,
- requested_entity_type, adj_ents );
- CHKERR(result, "iMesh_getEntArrAdj: trouble getting adjacency list.");
+ int source = CN::Dimension(TYPE_FROM_HANDLE(*entity_iter));
+ for (int bridge = min_bridge; bridge <= max_bridge; ++bridge) {
+ if (source == bridge)
+ continue;
+ for (int requested = min_req; requested <= max_req; ++requested) {
+ if (bridge == requested)
