[MOAB-dev] buildbot failure in Fathom on moab-distcheck
    moab-dev at mcs.anl.gov
    Wed Dec  1 00:13:23 CST 2010
The Fathomatic has detected a failed build of moab-distcheck on Fathom.
Full details are available at:
 http://gnep.mcs.anl.gov:8010/builders/moab-distcheck/builds/339
Buildbot URL: http://gnep.mcs.anl.gov:8010/
Buildslave for this Build: gnep
Build Reason: The Nightly scheduler named 'nightly' triggered this build
Build Source Stamp: None
Blamelist:
BUILD FAILED: failed compile
LOG EXCERPT:
ar cru .libs/libiMesh.a  iMesh_MOAB.o
ranlib .libs/libiMesh.a
creating libiMesh.la
(cd .libs && rm -f libiMesh.la && ln -s ../libiMesh.la libiMesh.la)
make[5]: Entering directory `/disk/itaps-buildslave/moab-distcheck/build/moab-3.99/_build/itaps'
make[5]: Nothing to be done for `all-am'.
Making all in tools
make[4]: Entering directory `/disk/itaps-buildslave/moab-distcheck/build/moab-3.99/_build/tools'
Making all in dagmc
make[5]: Entering directory `/disk/itaps-buildslave/moab-distcheck/build/moab-3.99/_build/tools/dagmc'
/bin/sh ../../libtool --tag=CXX   --mode=compile g++ -DHAVE_CONFIG_H -I. -I../../../tools/dagmc -I../.. -I../../src/moab -I../../src/parallel -I../../src  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE -I../../../src -I../../src  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT DagMC.lo -MD -MP -MF .deps/DagMC.Tpo -c -o DagMC.lo ../../../tools/dagmc/DagMC.cpp
 g++ -DHAVE_CONFIG_H -I. -I../../../tools/dagmc -I../.. -I../../src/moab -I../../src/parallel -I../../src -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64 -DHDF5_FILE -DNETCDF_FILE -I../../../src -I../../src -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT DagMC.lo -MD -MP -MF .deps/DagMC.Tpo -c ../../../tools/dagmc/DagMC.cpp -o DagMC.o
mv -f .deps/DagMC.Tpo .deps/DagMC.Plo
/bin/sh ../../libtool --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG   -o libdagmc.la -rpath /disk/itaps-buildslave/moab-distcheck/build/moab-3.99/_inst/lib DagMC.lo  -lm
mkdir .libs
ar cru .libs/libdagmc.a  DagMC.o
ranlib .libs/libdagmc.a
creating libdagmc.la
(cd .libs && rm -f libdagmc.la && ln -s ../libdagmc.la libdagmc.la)
g++ -DHAVE_CONFIG_H -I. -I../../../tools/dagmc -I../.. -I../../src/moab -I../../src/parallel -I../../src  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE -I../../../src -I../../src  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT quads_to_tris_driver.o -MD -MP -MF .deps/quads_to_tris_driver.Tpo -c -o quads_to_tris_driver.o ../../../tools/dagmc/quads_to_tris_driver.cpp
mv -f .deps/quads_to_tris_driver.Tpo .deps/quads_to_tris_driver.Po
g++ -DHAVE_CONFIG_H -I. -I../../../tools/dagmc -I../.. -I../../src/moab -I../../src/parallel -I../../src  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE -I../../../src -I../../src  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT quads_to_tris.o -MD -MP -MF .deps/quads_to_tris.Tpo -c -o quads_to_tris.o ../../../tools/dagmc/quads_to_tris.cpp
mv -f .deps/quads_to_tris.Tpo .deps/quads_to_tris.Po
/bin/sh ../../libtool --tag=CXX   --mode=link g++  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG   -o quads_to_tris quads_to_tris_driver.o quads_to_tris.o ../../src/libMOAB.la -lm
g++ -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -o quads_to_tris quads_to_tris_driver.o quads_to_tris.o  ../../src/.libs/libMOAB.a -lnetcdf_c++ -lnetcdf -L/usr/lib/mpich/lib/ /usr/lib/libhdf5.so -lpthread -lz -lm
g++ -DHAVE_CONFIG_H -I. -I../../../tools/dagmc -I../.. -I../../src/moab -I../../src/parallel -I../../src  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DHDF5_FILE -DNETCDF_FILE -I../../../src -I../../src  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -pedantic -Wno-long-long -O2 -DNDEBUG -MT dagmc_preproc.o -MD -MP -MF .deps/dagmc_preproc.Tpo -c -o dagmc_preproc.o ../../../tools/dagmc/dagmc_preproc.cpp
../../../tools/dagmc/dagmc_preproc.cpp:1:30: error: ../program_opt.hpp: No such file or directory
../../../tools/dagmc/dagmc_preproc.cpp: In function 'int main(int, char**)':
../../../tools/dagmc/dagmc_preproc.cpp:224: error: 'ProgOptions' was not declared in this scope
../../../tools/dagmc/dagmc_preproc.cpp:224: error: expected `;' before 'po'
../../../tools/dagmc/dagmc_preproc.cpp:229: error: 'po' was not declared in this scope
../../../tools/dagmc/dagmc_preproc.cpp:229: error: expected primary-expression before 'void'
../../../tools/dagmc/dagmc_preproc.cpp:229: error: expected `;' before 'void'
../../../tools/dagmc/dagmc_preproc.cpp:230: error: expected primary-expression before '>' token
../../../tools/dagmc/dagmc_preproc.cpp:230: warning: left-hand operand of comma has no effect
../../../tools/dagmc/dagmc_preproc.cpp:231: error: expected primary-expression before '>' token
../../../tools/dagmc/dagmc_preproc.cpp:231: warning: left-hand operand of comma has no effect
../../../tools/dagmc/dagmc_preproc.cpp:233: error: expected primary-expression before 'double'
../../../tools/dagmc/dagmc_preproc.cpp:233: error: expected `;' before 'double'
../../../tools/dagmc/dagmc_preproc.cpp:234: error: expected primary-expression before 'double'
../../../tools/dagmc/dagmc_preproc.cpp:234: error: expected `;' before 'double'
../../../tools/dagmc/dagmc_preproc.cpp:235: error: expected primary-expression before 'int'
../../../tools/dagmc/dagmc_preproc.cpp:235: error: expected `;' before 'int'
../../../tools/dagmc/dagmc_preproc.cpp:236: error: expected primary-expression before 'void'
../../../tools/dagmc/dagmc_preproc.cpp:236: error: expected `;' before 'void'
../../../tools/dagmc/dagmc_preproc.cpp:237: error: expected primary-expression before 'void'
../../../tools/dagmc/dagmc_preproc.cpp:237: error: expected `;' before 'void'
../../../tools/dagmc/dagmc_preproc.cpp:239: error: expected primary-expression before '>' token
../../../tools/dagmc/dagmc_preproc.cpp:239: warning: left-hand operand of comma has no effect
../../../tools/dagmc/dagmc_preproc.cpp:239: warning: right-hand operand of comma has no effect
sincerely,
 -The Fathomatic
