[MOAB-dev] r4298 - in MOAB/trunk: itaps/imesh src/parallel src/parallel/moab tools/mbcoupler
tautges at mcs.anl.gov
Tue Nov 23 11:25:24 CST 2010
Author: tautges
Date: 2010-11-23 11:25:24 -0600 (Tue, 23 Nov 2010)
New Revision: 4298
Modified:
MOAB/trunk/itaps/imesh/MOAB_iMeshP_unit_tests.cpp
MOAB/trunk/src/parallel/ParallelComm.cpp
MOAB/trunk/src/parallel/ProcConfig.cpp
MOAB/trunk/src/parallel/crystal.c
MOAB/trunk/src/parallel/crystal.h
MOAB/trunk/src/parallel/gs.c
MOAB/trunk/src/parallel/moab/ParallelComm.hpp
MOAB/trunk/src/parallel/transfer.c
MOAB/trunk/src/parallel/tuple_list.c
MOAB/trunk/src/parallel/tuple_list.h
MOAB/trunk/tools/mbcoupler/Coupler.cpp
Log:
- changing names of a few more gs functions to avoid name conflicts with Nek
- fixing bug resolving parallel interface for cases where a face's vertices are
shared across a number of procs but the face itself isn't shared
- adding some additional debug output in ParallelComm used to diagnose this problem
- fixing MOAB_iMeshP_unit_tests for when run on one proc, which was dying inside
MPI_Gatherv in the single-proc case; shouldn't really die there, but couldn't figure out
what else to do
- adding ParallelComm::get_pstatus
Passes make check in serial and parallel.
Modified: MOAB/trunk/itaps/imesh/MOAB_iMeshP_unit_tests.cpp
--- MOAB/trunk/itaps/imesh/MOAB_iMeshP_unit_tests.cpp 2010-11-23 13:48:36 UTC (rev 4297)
+++ MOAB/trunk/itaps/imesh/MOAB_iMeshP_unit_tests.cpp 2010-11-23 17:25:24 UTC (rev 4298)
@@ -1896,10 +1896,17 @@
// collect all data on root procesor
std::vector<int> all_data( 2*global_count );
std::vector<int> displ(size), counts(size);
- ierr = MPI_Gatherv( &vtxdata[0], vtxdata.size(), MPI_INT,
- &all_data[0], &counts[0], &displ[0], MPI_INT,
- 0, MPI_COMM_WORLD );
- CHKERR;
+ if (1 == size) {
+ std::copy(vtxdata.begin(), vtxdata.end(), all_data.begin());
+ counts[0] = vtxdata.size();
+ displ[0] = 0;
+ else {
+ ierr = MPI_Gatherv( &vtxdata[0], vtxdata.size(), MPI_INT,
+ &all_data[0], &counts[0], &displ[0], MPI_INT,
+ 0, MPI_COMM_WORLD );
+ CHKERR;
if (rank == 0) {
// map from vertex tag to indices into data
std::multimap<int,int> data_map;
Modified: MOAB/trunk/src/parallel/ParallelComm.cpp
--- MOAB/trunk/src/parallel/ParallelComm.cpp 2010-11-23 13:48:36 UTC (rev 4297)
+++ MOAB/trunk/src/parallel/ParallelComm.cpp 2010-11-23 17:25:24 UTC (rev 4298)
@@ -33,7 +33,6 @@
extern "C"
#include "types.h"
-#include "minmax.h"
#include "gs.h"
#include "errmem.h"
#include "sort.h"
@@ -499,6 +498,7 @@
std::vector<unsigned int>::iterator vit =
std::find(buffProcs.begin(), buffProcs.end(), to_proc);
if (vit == buffProcs.end()) {
+ assert("shouldn't need buffer to myself" && to_proc != (int)procConfig.proc_rank());
ind = buffProcs.size();
buffProcs.push_back((unsigned int)to_proc);
localOwnedBuffs.push_back(new Buffer(INITIAL_BUFF_SIZE));
@@ -1198,8 +1198,21 @@
// now add others, with zero handle for now
for (std::set<unsigned int>::iterator sit = procs.begin();
sit != procs.end(); sit++) {
