[MOAB-dev] buildbot failure in Fathom on moab-par
    moab-dev at mcs.anl.gov
    Tue Nov 23 00:06:49 CST 2010
The Fathomatic has detected a failed build of moab-par on Fathom.
Full details are available at:
 http://gnep.mcs.anl.gov:8010/builders/moab-par/builds/342
Buildbot URL: http://gnep.mcs.anl.gov:8010/
Buildslave for this Build: gnep
Build Reason: The Nightly scheduler named 'nightly' triggered this build
Build Source Stamp: None
Blamelist:
BUILD FAILED: failed test
LOG EXCERPT:
Warning: acis file has sequence numbers!
allsent ents compactness (size) = 0.923077 (208)
Sent ents compactness (size) = 0.923077 (208)
Running test_write_shared_sets ...
allsent ents compactness (size) = allsent ents compactness (size) = 0.923077 (208)
0.923077 (208)
Running test_var_length_parallel ...
Running test_read_elements ...
Running test_read_elements_by_rank ...
Running test_read_tags ...
Running test_read_global_tags ...
Running test_read_sets ...
PASS: parallel_hdf5_test
PASS: mhdf_parallel
Using default interval count: 2
allsent ents compactness (size) = 2.5 (16)
Sent ents compactness (size) = 2.5 (16)
00:   0.01: Generating mesh
00:   0.01: Resolving shared entities
00:   0.02: Beginning parallel write
allsent ents compactness (size) = 2 (16)
Sent ents compactness (size) = 2 (16)
01:   0.00: Generating mesh
01:   0.00: Resolving shared entities
01:   0.00: Beginning parallel write
Wrote 16 hexes in 0 seconds.
Wall time: generate: 0.000693083, resovle shared: 0.00172305, write_file: 0.0173841
00:   0.02: Removing written file
00:   0.02: Finalizing MPI
01:   0.01: Finalizing MPI
PASS: parallel_write_test
1 of 8 tests failed
sincerely,
 -The Fathomatic
