[MOAB-dev] buildbot failure in Fathom on moab-par
    moab-dev at mcs.anl.gov
    Mon Nov 22 00:05:38 CST 2010
The Fathomatic has detected a failed build of moab-par on Fathom.
Full details are available at:
 http://gnep.mcs.anl.gov:8010/builders/moab-par/builds/340
Buildbot URL: http://gnep.mcs.anl.gov:8010/
Buildslave for this Build: gnep
Build Reason: The Nightly scheduler named 'nightly' triggered this build
Build Source Stamp: None
Blamelist:
BUILD FAILED: failed test
LOG EXCERPT:
   entityset_tag_test: Success
   mesh_tag_test: Success
   set_remove_contained_regression: Success
   all_adjacency_regression: Success
   error_code_test: Success
   ordered_set_regression: Success
   array_allocation_regression: Success
TSTT TEST SUMMARY:
   Number Tests:           14
   Number Successful:      14
   Number Not Implemented: 0
   Number Failed:          0
PASS: testc_cbind
Running test_getEntArrAdj_conn ...
Running test_getEntArrAdj_vertex ...
Running test_getEntArrAdj_up ...
Running test_getEntArrAdj_down ...
Running test_getEntArrAdj_invalid_size ...
Running test_getEntArrAdj_none ...
All 6 tests passed.
PASS: MOAB_iMesh_unit_tests
Hello
imesh assert
There's 0 entity sets here
Done
PASS: partest
Invalid/unexpected global part count at MOAB_iMeshP_unit_tests.cpp:2744 (proc 0):
  Expected: 1
  Actual:   0
Error code  1 at MOAB_iMeshP_unit_tests.cpp:694
Failed to load input mesh.
Cannot run further tests.
ABORTING
/bin/sh: line 4: 17650 Aborted                 ${dir}$tst
FAIL: MOAB_iMeshP_unit_tests
1 of 4 tests failed
sincerely,
 -The Fathomatic
