[MOAB-dev] ReadCGM question
    Brandon Smith
    bmsmith6 at wisc.edu
    Wed Nov  3 16:03:43 CDT 2010
Is there a way to track the maximum merge tolerance used when creating a model
in Cubit? Does this live as an attribute in the ACIS file?
Brandon
To: Steve Jackson <sjackson at cae.wisc.edu>; Developer correspondence for MOAB
<moab-dev at lists.mcs.anl.gov>
Sent: Wed, November 3, 2010 3:53:43 PM
Subject: Re: [MOAB-dev] ReadCGM question
On 11/03/2010 03:43 PM, Steve Jackson wrote:
> * I think it would it be more correct to replace GEOMETRY_RESABS with
> faceting_tol, i.e. the tolerance value that was used in calling
> edge->get_graphics().  Does anyone disagree?
Perhaps you could change it to be the merge tolerance.  Merging is
(hopefully) the source of such warnings.
- jason
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20101103/f2e82ede/attachment.htm>
