[MOAB-dev] r4231 - MOAB/trunk/itaps/igeom
iulian at mcs.anl.gov
Wed Oct 20 22:49:34 CDT 2010
Author: iulian
Date: 2010-10-20 22:49:33 -0500 (Wed, 20 Oct 2010)
New Revision: 4231
Modified:
MOAB/trunk/itaps/igeom/SmoothFaceEval.cpp
MOAB/trunk/itaps/igeom/iGeom_MOAB.cpp
Log:
the obb tree needs to be constructed before getting the root for a
geometric surface :)
the performance was very bad, as the tree root retrieved in the constructor of
SmoothFace was NULL; a lot of triangles were verified
Modified: MOAB/trunk/itaps/igeom/SmoothFaceEval.cpp
--- MOAB/trunk/itaps/igeom/SmoothFaceEval.cpp 2010-10-20 23:04:37 UTC (rev 4230)
+++ MOAB/trunk/itaps/igeom/SmoothFaceEval.cpp 2010-10-21 03:49:33 UTC (rev 4231)
@@ -58,7 +58,11 @@
//_mbOut->create_meshset(MESHSET_SET, _oSet); //will contain the
// get also the obb_root
if (_my_geomTopoTool)
_my_geomTopoTool->get_root(this->_set, _obb_root);
+ if (debug_surf_eval1)
+ _my_geomTopoTool->obb_tree()->stats(_obb_root, std::cout);
SmoothFaceEval::~SmoothFaceEval() {
Modified: MOAB/trunk/itaps/igeom/iGeom_MOAB.cpp
--- MOAB/trunk/itaps/igeom/iGeom_MOAB.cpp 2010-10-20 23:04:37 UTC (rev 4230)
+++ MOAB/trunk/itaps/igeom/iGeom_MOAB.cpp 2010-10-21 03:49:33 UTC (rev 4231)
@@ -83,6 +83,16 @@
int numSurfaces = _my_gsets[2].size();
//SmoothFaceEval ** smthFace = new SmoothFaceEval *[numSurfaces];
_smthFace = new SmoothFaceEval *[numSurfaces];
+ if (!t_created) {
+ GETGTT(instance);
+ rval = _my_geomTopoTool->construct_obb_trees();
+ if (rval != MB_SUCCESS)
+ std::cout << "Failed to construct obb tree.\n";
+ return false;
+ t_created = true;
// there should also be a map from surfaces to evaluators
//std::map<MBEntityHandle, SmoothFaceEval*> mapSurfaces;
