[MOAB-dev] buildbot failure in Fathom on moab-distcheck
    tautges at mcs.anl.gov
    Wed Oct 20 07:51:19 CDT 2010
Drat, forgot to add mesh files to distribution files.  Jim, could you
add cubtest12.cub and cubtest.jou to extra_dist in MeshFiles/unittest/
io/Makefile.am for me?  Thx.
- tim
On Oct 20, 2010, at 1:16 AM, moab-dev at mcs.anl.gov wrote:
> The Fathomatic has detected a failed build of moab-distcheck on
> Fathom.
> Full details are available at:
> http://gnep.mcs.anl.gov:8010/builders/moab-distcheck/builds/297
> Buildbot URL: http://gnep.mcs.anl.gov:8010/
> Buildslave for this Build: gnep
> Build Reason: The Nightly scheduler named 'nightly' triggered this
> build
> Build Source Stamp: None
> Blamelist:
> BUILD FAILED: failed compile
> LOG EXCERPT:
> Running test_quad5 ...
> Running test_quad8 ...
> Running test_quad9 ...
> Running test_tet8 ...
> Running test_tet10 ...
> Running test_tet14 ...
> Running test_hex9 ...
> Running test_hex20 ...
> Running test_hex27 ...
> Running test_read_tri6_side ...
> Running test_read_shell_side ...
> Running test_read_shell_edge ...
> Running test_read_hex20_side ...
> Running test_read_block_ids ...
> Running test_read_sideset_ids ...
> Running test_read_nodeset_ids ...
> PASS: exodus_test
> Running test_read_nodes ...
> Running test_read_quads ...
> Running test_read_material_set ...
> Running test_read_geom_set ...
> PASS: gmsh_test
> Running test_read_tets ...
> Running test_read_prisms ...
> Running test_read_hexes ...
> Running test_read_material_set1 ...
> Running test_read_material_set2 ...
> PASS: nastran_test
> Running test_read_physical_set ...
> PASS: ideas_test
> Running test_read_ascii ...
> Running test_write_ascii ...
> Running test_type_option ...
> Running test_detect_type ...
> Running test_endian_option ...
> Running test_big_endian ...
> Running test_little_endian ...
> Running test_detect_byte_order ...
> PASS: stl_test
> Running test_read_triangles ...
> PASS: smf_test
> 1 of 9 tests failed
> sincerely,
> -The Fathomatic
