[MOAB-dev] r4221 - MOAB/trunk/itaps/igeom
iulian at mcs.anl.gov iulian at mcs.anl.gov
Fri Oct 15 20:35:04 CDT 2010
Author: iulian
Date: 2010-10-15 20:35:04 -0500 (Fri, 15 Oct 2010)
New Revision: 4221
Modified:
   MOAB/trunk/itaps/igeom/SmoothFaceEval.cpp
   MOAB/trunk/itaps/igeom/SmoothFaceEval.hpp
   MOAB/trunk/itaps/igeom/iGeom_MOAB.cpp
   MOAB/trunk/itaps/igeom/testSmooth.cc
Log:
Implement the method iGeom_getPntRayIntsct
it may be inefficient
add also a ray_test
the method will be used for trimming/cutting surfaces
Could be also used for sweeping to a surface
Modified: MOAB/trunk/itaps/igeom/SmoothFaceEval.cpp
--- MOAB/trunk/itaps/igeom/SmoothFaceEval.cpp	2010-10-14 16:58:41 UTC (rev 4220)
+++ MOAB/trunk/itaps/igeom/SmoothFaceEval.cpp	2010-10-16 01:35:04 UTC (rev 4221)
@@ -1941,4 +1941,47 @@
    return MB_SUCCESS;
+moab::ErrorCode SmoothFaceEval::ray_intersection_correct(moab::EntityHandle facet, // (IN) the facet where the patch is defined
+         moab::CartVect &pt, // (IN) shoot from
+         moab::CartVect &ray, // (IN) ray direction
+         moab::CartVect &eval_pt, // (INOUT) The intersection point
+         double & distance, // (IN OUT) the new distance
+         bool &outside)
+   // find a point on the smooth surface
+   moab::CartVect currentPoint = eval_pt;
+   int numIter = 0;
+   double improvement = 1.e20;
+   moab::CartVect diff;
+   while (numIter++ < 5 && improvement > 0.01)
+      moab::CartVect newPos;
+      bool trim = false;// is it needed?
+      bool outside = true;
+      moab::CartVect closestPoint;
+      moab::CartVect normal;
+      moab::ErrorCode rval = project_to_facets_main(currentPoint, trim, outside,
+               &newPos, &normal);
+      diff = newPos - currentPoint;
+      improvement = diff.length();
+      // ( pt + t * ray - closest ) % normal = 0;
+      // intersect tangent plane that goes through closest point with the direction
+      // t = normal%(closest-pt) / normal%ray;
+      double dot = normal%ray; // if it is 0, get out while we can
+      if (dot < 0.00001)
+         // bad convergence, get out, do not modify anything
+         return MB_SUCCESS;
+      double t = ((newPos-pt)%normal) / (dot);
+      currentPoint = pt + t * ray;
+   eval_pt = currentPoint;
+   diff = currentPoint - pt;
+   distance = diff.length();
