Author: iulian
Date: 2010-10-08 16:49:29 -0500 (Fri, 08 Oct 2010)
New Revision: 4208
Modified:
MOAB/trunk/itaps/igeom/SmoothFaceEval.cpp
MOAB/trunk/itaps/igeom/iGeom_MOAB.cpp
Log:
implement some extra methods needed
decide which one is the first vertex in the edge
return the sense of the edge in face
Modified: MOAB/trunk/itaps/igeom/SmoothFaceEval.cpp
--- MOAB/trunk/itaps/igeom/SmoothFaceEval.cpp 2010-10-08 17:21:22 UTC (rev 4207)
+++ MOAB/trunk/itaps/igeom/SmoothFaceEval.cpp 2010-10-08 21:49:29 UTC (rev 4208)
@@ -49,7 +49,7 @@
return MB_FAILURE;// face not found in list
-extern bool debug_surf_eval;
+bool debug_surf_eval1 = false;
SmoothFaceEval::SmoothFaceEval(moab::Interface * mb,
moab::EntityHandle surface_set, moab::GeomTopoTool * gTool) :
@@ -117,7 +117,7 @@
void SmoothFaceEval::move_to_surface(double& x, double& y, double& z,
double& u_guess, double& v_guess) {
- if (debug_surf_eval) {
+ if (debug_surf_eval1) {
std::cout << "move_to_surface called." << std::endl;
@@ -273,7 +273,7 @@
// reset the normal values after normalization
_mb->tag_set_data(_gradientTag, _nodes, normalVal);
// print the loops size and some other stuff
std::cout << " normals at " << numNodes << " nodes" << std::endl;
int i = 0;
for (moab::Range::iterator it = _nodes.begin(); it != _nodes.end(); it++, i++) {
@@ -337,7 +337,7 @@
rval = _mb->tag_set_data(_edgeCtrlTag, &edge, 1, &ctrl_pts[0]);
assert(rval == MB_SUCCESS);
std::cout << "edge: " << _mb-> id_from_handle(edge) << " tangents: "
<< T[0] << T[1] << std::endl;
std::cout << " points: " << P[0] << " " << P[1] << std::endl;
@@ -1921,7 +1921,7 @@
if (startVert != currentVert)
return MB_FAILURE;
// print the loops found so far
std::cout << "number of loops" << _loopEnds.size() << std::endl;
for (size_t i = 0; i < _loopEnds.size(); i++) {
Modified: MOAB/trunk/itaps/igeom/iGeom_MOAB.cpp
