[MOAB-dev] r4189 - MOAB/trunk/test/h5file
    Tim Tautges
    tautges at mcs.anl.gov
    Mon Oct  4 08:19:12 CDT 2010
Thanks!
- tim
On 10/04/2010 08:09 AM, kraftche at cae.wisc.edu wrote:
> Author: kraftche
> Date: 2010-10-04 08:09:41 -0500 (Mon, 04 Oct 2010)
> New Revision: 4189
> Modified:
>     MOAB/trunk/test/h5file/h5portable.cpp
> Log:
> fix 64-bit build with 32-bit handles
> Modified: MOAB/trunk/test/h5file/h5portable.cpp
> --- MOAB/trunk/test/h5file/h5portable.cpp	2010-10-04 12:57:22 UTC (rev 4188)
> +++ MOAB/trunk/test/h5file/h5portable.cpp	2010-10-04 13:09:41 UTC (rev 4189)
> @@ -34,9 +34,9 @@
>   const double default_real_tag[] = { -1, -2, -3, -4, -5, -6, -7, -8 };
>   const double mesh_real_tag[] = { 8, 7, 6, 5, 4, 3, 2, 1 };
> -const size_t INTERVALS = 8;
> -const size_t NUM_VERT = (INTERVALS+1)*(INTERVALS+1);
> -const size_t NUM_QUAD = INTERVALS * INTERVALS;
> +const EntityHandle INTERVALS = 8;
> +const EntityHandle NUM_VERT = (INTERVALS+1)*(INTERVALS+1);
> +const EntityHandle NUM_QUAD = INTERVALS * INTERVALS;
>   const double Z = 0.0;
>   const double EPS = std::numeric_limits<double>::epsilon();
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
