[MOAB-dev] buildbot failure in Fathom on moab-32bit-handles
    moab-dev at mcs.anl.gov
    Thu Sep 30 00:09:54 CDT 2010
The Fathomatic has detected a failed build of moab-32bit-handles on Fathom.
Full details are available at:
 http://gnep.mcs.anl.gov:8010/builders/moab-32bit-handles/builds/241
Buildbot URL: http://gnep.mcs.anl.gov:8010/
Buildslave for this Build: gnep
Build Reason: The Nightly scheduler named 'nightly' triggered this build
Build Source Stamp: None
Blamelist:
BUILD FAILED: failed test
LOG EXCERPT:
g++ -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src/parallel -I../../src  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64 -DHDF5_FILE -DNETCDF_FILE -DSRCDIR=. -DMESHDIR=../../MeshFiles/unittest -I../../src -I../../src -I.. -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -O2 -DNDEBUG -MT obb_time.o -MD -MP -MF .deps/obb_time.Tpo -c -o obb_time.o obb_time.cpp
mv -f .deps/obb_time.Tpo .deps/obb_time.Po
/bin/sh ../../libtool --tag=CXX   --mode=link g++  -Wall -pipe -O2 -DNDEBUG   -o obb_time obb_time.o ../../src/libMOAB.la -lm
g++ -Wall -pipe -O2 -DNDEBUG -o obb_time obb_time.o  ../../src/.libs/libMOAB.a -lnetcdf_c++ -lnetcdf -L/usr/lib/mpich/lib/ /usr/lib/libhdf5.so -lpthread -lz -lm
g++ -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src/parallel -I../../src  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64 -DHDF5_FILE -DNETCDF_FILE -DSRCDIR=. -DMESHDIR=../../MeshFiles/unittest -I../../src -I../../src -I.. -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -O2 -DNDEBUG -MT obb_tree_tool.o -MD -MP -MF .deps/obb_tree_tool.Tpo -c -o obb_tree_tool.o obb_tree_tool.cpp
mv -f .deps/obb_tree_tool.Tpo .deps/obb_tree_tool.Po
/bin/sh ../../libtool --tag=CXX   --mode=link g++  -Wall -pipe -O2 -DNDEBUG   -o obb_tree_tool obb_tree_tool.o ../../src/libMOAB.la -lm
g++ -Wall -pipe -O2 -DNDEBUG -o obb_tree_tool obb_tree_tool.o  ../../src/.libs/libMOAB.a -lnetcdf_c++ -lnetcdf -L/usr/lib/mpich/lib/ /usr/lib/libhdf5.so -lpthread -lz -lm
make  check-TESTS
make[4]: Entering directory `/disk/itaps-buildslave/moab-32bit-handles/build/test/obb'
MOAB 3.99 (Alpha)
No file(s) specified.
Using default file "../../MeshFiles/unittest/3k-tri-sphere.vtk"
Using default file "../../MeshFiles/unittest/3k-tri-cube.h5m"
Building tree from 2970 2D elements
No errors detected.
Building tree from 6 surfaces
Built tree from 6 surfaces (2934 elements)
No errors detected.
PASS: obb_test
All 1 tests passed
Making check in perf
make[3]: Entering directory `/disk/itaps-buildslave/moab-32bit-handles/build/test/perf'
make  perf seqperf adj_time tstt_perf_binding
make[4]: Entering directory `/disk/itaps-buildslave/moab-32bit-handles/build/test/perf'
g++ -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src/parallel -I../../src  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64 -DHDF5_FILE -DNETCDF_FILE -I../../src -I../../src/io/mhdf/include -I../../src  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -O2 -DNDEBUG -MT perf.o -MD -MP -MF .deps/perf.Tpo -c -o perf.o perf.cpp
mv -f .deps/perf.Tpo .deps/perf.Po
/bin/sh ../../libtool --tag=CXX   --mode=link g++  -Wall -pipe -O2 -DNDEBUG   -o perf perf.o ../../src/libMOAB.la  -lm
g++ -Wall -pipe -O2 -DNDEBUG -o perf perf.o  ../../src/.libs/libMOAB.a -lnetcdf_c++ -lnetcdf -L/usr/lib/mpich/lib/ /usr/lib/libhdf5.so -lpthread -lz -lm
g++ -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src/parallel -I../../src  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64 -DHDF5_FILE -DNETCDF_FILE -I../../src -I../../src/io/mhdf/include -I../../src  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -O2 -DNDEBUG -MT seqperf.o -MD -MP -MF .deps/seqperf.Tpo -c -o seqperf.o seqperf.cpp
mv -f .deps/seqperf.Tpo .deps/seqperf.Po
/bin/sh ../../libtool --tag=CXX   --mode=link g++  -Wall -pipe -O2 -DNDEBUG   -o seqperf seqperf.o ../../src/libMOAB.la  -lm
g++ -Wall -pipe -O2 -DNDEBUG -o seqperf seqperf.o  ../../src/.libs/libMOAB.a -lnetcdf_c++ -lnetcdf -L/usr/lib/mpich/lib/ /usr/lib/libhdf5.so -lpthread -lz -lm
g++ -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src/parallel -I../../src  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64 -DHDF5_FILE -DNETCDF_FILE -I../../src -I../../src/io/mhdf/include -I../../src  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -O2 -DNDEBUG -MT adj_time.o -MD -MP -MF .deps/adj_time.Tpo -c -o adj_time.o adj_time.cpp
mv -f .deps/adj_time.Tpo .deps/adj_time.Po
/bin/sh ../../libtool --tag=CXX   --mode=link g++  -Wall -pipe -O2 -DNDEBUG   -o adj_time adj_time.o ../../src/libMOAB.la  -lm
g++ -Wall -pipe -O2 -DNDEBUG -o adj_time adj_time.o  ../../src/.libs/libMOAB.a -lnetcdf_c++ -lnetcdf -L/usr/lib/mpich/lib/ /usr/lib/libhdf5.so -lpthread -lz -lm
/bin/sh ../../libtool --tag=CXX   --mode=link g++  -Wall -pipe -O2 -DNDEBUG   -o tstt_perf_binding  ../../src/libMOAB.la  -lm
g++ -Wall -pipe -O2 -DNDEBUG -o tstt_perf_binding  ../../src/.libs/libMOAB.a -lnetcdf_c++ -lnetcdf -L/usr/lib/mpich/lib/ /usr/lib/libhdf5.so -lpthread -lz -lm
/usr/lib/gcc/x86_64-linux-gnu/4.2.4/../../../../lib/crt1.o: In function `_start':
(.text+0x20): undefined reference to `main'
collect2: ld returned 1 exit status
sincerely,
 -The Fathomatic
