[MOAB-dev] r4174 - MOAB/trunk/src
kraftche at cae.wisc.edu
Tue Sep 28 09:54:55 CDT 2010
Author: kraftche
Date: 2010-09-28 09:54:54 -0500 (Tue, 28 Sep 2010)
New Revision: 4174
Modified:
MOAB/trunk/src/BitTagServer.cpp
MOAB/trunk/src/BitTagServer.hpp
Log:
fix bug in bit tag server
Modified: MOAB/trunk/src/BitTagServer.cpp
--- MOAB/trunk/src/BitTagServer.cpp 2010-09-28 12:43:44 UTC (rev 4173)
+++ MOAB/trunk/src/BitTagServer.cpp 2010-09-28 14:54:54 UTC (rev 4174)
@@ -60,10 +60,10 @@
ErrorCode BitTagServer::get_tags( EntityHandle entity,
- std::vector<Tag> &tags ) const
+ std::vector<Tag> &tags ) const
- for (size_t i = 0; i < tagList.size(); ++i)
- if (tagList[i].in_use())
+ for (size_t i = 0; i < tagList.size(); ++i)
+ if (tagList[i].in_use() && tagList[i].is_tagged(entity))
tags.push_back( (Tag)(i+1) );
return MB_SUCCESS;
@@ -334,7 +334,7 @@
EntityHandle last = h + per_page - 1;
// never zero ID
if (!id) ++h;
- hint = entities.insert( h, last );
+ hint = entities.insert( hint, h, last );
return MB_SUCCESS;
Modified: MOAB/trunk/src/BitTagServer.hpp
--- MOAB/trunk/src/BitTagServer.hpp 2010-09-28 12:43:44 UTC (rev 4173)
+++ MOAB/trunk/src/BitTagServer.hpp 2010-09-28 14:54:54 UTC (rev 4174)
@@ -233,6 +233,8 @@
EntityType type,
int& num_entities ) const;
+ bool is_tagged( EntityHandle h ) const;
ErrorCode get_memory_use( unsigned long& total,
unsigned long& per_entity ) const;
@@ -462,6 +464,14 @@
set_bits( offset++, per_ent, value );
+inline bool BitTag::is_tagged( EntityHandle h ) const
+ EntityType type;
+ size_t page;
+ int offset;
+ unpack( h, type, page, offset );
