[MOAB-dev] buildbot failure in Fathom on moab-shared
    moab-dev at mcs.anl.gov
    Mon Sep 27 00:16:57 CDT 2010
The Fathomatic has detected a failed build of moab-shared on Fathom.
Full details are available at:
 http://gnep.mcs.anl.gov:8010/builders/moab-shared/builds/237
Buildbot URL: http://gnep.mcs.anl.gov:8010/
Buildslave for this Build: gnep
Build Reason:
Build Source Stamp: None
Blamelist:
BUILD FAILED: failed compile
LOG EXCERPT:
 g++ -DHAVE_CONFIG_H -I. -I.. -I../src/moab -I../src/parallel -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64 -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I./io -I./io/mhdf/include -I./parallel -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -Wall -pipe -O2 -DNDEBUG -MT VertexSequence.lo -MD -MP -MF .deps/VertexSequence.Tpo -c VertexSequence.cpp  -fPIC -DPIC -o .libs/VertexSequence.o
 g++ -DHAVE_CONFIG_H -I. -I.. -I../src/moab -I../src/parallel -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64 -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I./io -I./io/mhdf/include -I./parallel -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -Wall -pipe -O2 -DNDEBUG -MT VertexSequence.lo -MD -MP -MF .deps/VertexSequence.Tpo -c VertexSequence.cpp -o VertexSequence.o >/dev/null 2>&1
mv -f .deps/VertexSequence.Tpo .deps/VertexSequence.Plo
/bin/sh ../libtool --tag=CXX   --mode=link g++  -Wall -pipe -O2 -DNDEBUG   -o libMOAB.la -rpath /disk/itaps-buildslave/packages/moab-shared/lib AEntityFactory.lo BitTagServer.lo BSPTreePoly.lo DebugOutput.lo DualTool.lo EntitySequence.lo FileOptions.lo GeomTopoTool.lo HigherOrderFactory.lo HomXform.lo AdaptiveKDTree.lo AffineXform.lo AxisBox.lo BSPTree.lo CN.lo CartVect.lo Matrix3.lo Core.lo Factory.lo GeomUtil.lo MeshSet.lo OrientedBox.lo OrientedBoxTreeTool.lo Range.lo RangeSeqIntersectIter.lo ReadUtil.lo ReaderWriterSet.lo Skinner.lo SysUtil.lo Util.lo WriteUtil.lo MeshSetSequence.lo MeshTopoUtil.lo PolyElementSeq.lo ScdElementData.lo ScdVertexData.lo SequenceData.lo SequenceManager.lo SparseTagSuperCollection.lo SparseTagCollection.lo StructuredElementSeq.lo SweptElementData.lo SweptElementSeq.lo SweptVertexData.lo TagInfo.lo TagServer.lo TypeSequenceManager.lo UnstructuredElemSeq.lo VertexSequence.lo io/libmoabio.la  -lm
g++ -shared -nostdlib /usr/lib/gcc/x86_64-linux-gnu/4.2.4/../../../../lib/crti.o /usr/lib/gcc/x86_64-linux-gnu/4.2.4/crtbeginS.o  .libs/AEntityFactory.o .libs/BitTagServer.o .libs/BSPTreePoly.o .libs/DebugOutput.o .libs/DualTool.o .libs/EntitySequence.o .libs/FileOptions.o .libs/GeomTopoTool.o .libs/HigherOrderFactory.o .libs/HomXform.o .libs/AdaptiveKDTree.o .libs/AffineXform.o .libs/AxisBox.o .libs/BSPTree.o .libs/CN.o .libs/CartVect.o .libs/Matrix3.o .libs/Core.o .libs/Factory.o .libs/GeomUtil.o .libs/MeshSet.o .libs/OrientedBox.o .libs/OrientedBoxTreeTool.o .libs/Range.o .libs/RangeSeqIntersectIter.o .libs/ReadUtil.o .libs/ReaderWriterSet.o .libs/Skinner.o .libs/SysUtil.o .libs/Util.o .libs/WriteUtil.o .libs/MeshSetSequence.o .libs/MeshTopoUtil.o .libs/PolyElementSeq.o .libs/ScdElementData.o .libs/ScdVertexData.o .libs/SequenceData.o .libs/SequenceManager.o .libs/SparseTagSuperCollection.o .libs/SparseTagCollection.o .libs/StructuredElementSeq.o .libs/SweptElementData.o .
 libs/SweptElementSeq.o .libs/SweptVertexData.o .libs/TagInfo.o .libs/TagServer.o .libs/TypeSequenceManager.o .libs/UnstructuredElemSeq.o .libs/VertexSequence.o -Wl,--whole-archive io/.libs/libmoabio.a -Wl,--no-whole-archive  -lnetcdf_c++ -lnetcdf -L/usr/lib/mpich/lib/ /usr/lib/libhdf5.so -lpthread -lz -L/usr/lib/gcc/x86_64-linux-gnu/4.2.4 -L/usr/lib/gcc/x86_64-linux-gnu/4.2.4/../../../../lib -L/lib/../lib -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.2.4/../../.. -lstdc++ -lm -lc -lgcc_s /usr/lib/gcc/x86_64-linux-gnu/4.2.4/crtendS.o /usr/lib/gcc/x86_64-linux-gnu/4.2.4/../../../../lib/crtn.o  -Wl,-soname -Wl,libMOAB.so.0 -o .libs/libMOAB.so.0.0.0
(cd .libs && rm -f libMOAB.so.0 && ln -s libMOAB.so.0.0.0 libMOAB.so.0)
(cd .libs && rm -f libMOAB.so && ln -s libMOAB.so.0.0.0 libMOAB.so)
rm -fr .libs/libMOAB.lax
mkdir .libs/libMOAB.lax
rm -fr .libs/libMOAB.lax/libmoabio.a
mkdir .libs/libMOAB.lax/libmoabio.a
(cd .libs/libMOAB.lax/libmoabio.a && ar x /disk/itaps-buildslave/moab-shared/build/src/io/.libs/libmoabio.a)
ar cru .libs/libMOAB.a  AEntityFactory.o BitTagServer.o BSPTreePoly.o DebugOutput.o DualTool.o EntitySequence.o FileOptions.o GeomTopoTool.o HigherOrderFactory.o HomXform.o AdaptiveKDTree.o AffineXform.o AxisBox.o BSPTree.o CN.o CartVect.o Matrix3.o Core.o Factory.o GeomUtil.o MeshSet.o OrientedBox.o OrientedBoxTreeTool.o Range.o RangeSeqIntersectIter.o ReadUtil.o ReaderWriterSet.o Skinner.o SysUtil.o Util.o WriteUtil.o MeshSetSequence.o MeshTopoUtil.o PolyElementSeq.o ScdElementData.o ScdVertexData.o SequenceData.o SequenceManager.o SparseTagSuperCollection.o SparseTagCollection.o StructuredElementSeq.o SweptElementData.o SweptElementSeq.o SweptVertexData.o TagInfo.o TagServer.o TypeSequenceManager.o UnstructuredElemSeq.o VertexSequence.o  .libs/libMOAB.lax/libmoabio.a/nodes.o .libs/libMOAB.lax/libmoabio.a/WriteNCDF.o .libs/libMOAB.lax/libmoabio.a/ReadVtk.o .libs/libMOAB.lax/libmoabio.a/ReadSmf.o .libs/libMOAB.lax/libmoabio.a/ReadHDF5.o .libs/libMOAB.lax/libmoabio.a/GmshUtil
 .o .libs/libMOAB.lax/libmoabio.a/ReadNC.o .libs/libMOAB.lax/libmoabio.a/adjacency.o .libs/libMOAB.lax/libmoabio.a/ReadNCDF.o .libs/libMOAB.lax/libmoabio.a/ReadGmsh.o .libs/libMOAB.lax/libmoabio.a/ReadSTL.o .libs/libMOAB.lax/libmoabio.a/WriteGMV.o .libs/libMOAB.lax/libmoabio.a/ExoIIUtil.o .libs/libMOAB.lax/libmoabio.a/SMF_State.o .libs/libMOAB.lax/libmoabio.a/WriteTemplate.o .libs/libMOAB.lax/libmoabio.a/WriteSTL.o .libs/libMOAB.lax/libmoabio.a/WriteSmf.o .libs/libMOAB.lax/libmoabio.a/FileTokenizer.o .libs/libMOAB.lax/libmoabio.a/util.o .libs/libMOAB.lax/libmoabio.a/ReadMCNP5.o .libs/libMOAB.lax/libmoabio.a/WriteHDF5.o .libs/libMOAB.lax/libmoabio.a/file.o .libs/libMOAB.lax/libmoabio.a/file-handle.o .libs/libMOAB.lax/libmoabio.a/WriteGmsh.o .libs/libMOAB.lax/libmoabio.a/WriteSLAC.o .libs/libMOAB.lax/libmoabio.a/VtkUtil.o .libs/libMOAB.lax/libmoabio.a/WriteAns.o .libs/libMOAB.lax/libmoabio.a/IODebugTrack.o .libs/libMOAB.lax/libmoabio.a/ReadIDEAS.o .libs/libMOAB.lax/libmoabio.a/
 ReadSms.o .libs/libMOAB.lax/libmoabio.a/ReadABAQUS.o .libs/libMOAB.lax/libmoabio.a/connectivity.o .libs/libMOAB.lax/libmoabio.a/tags.o .libs/libMOAB.lax/libmoabio.a/WriteVtk.o .libs/libMOAB.lax/libmoabio.a/status.o .libs/libMOAB.lax/libmoabio.a/Tqdcfr.o .libs/libMOAB.lax/libmoabio.a/file-desc.o .libs/libMOAB.lax/libmoabio.a/ReadTetGen.o .libs/libMOAB.lax/libmoabio.a/sets.o .libs/libMOAB.lax/libmoabio.a/ReadNASTRAN.o .libs/libMOAB.lax/libmoabio.a/ReadHDF5Dataset.o
ranlib .libs/libMOAB.a
creating libMOAB.la
(cd .libs && rm -f libMOAB.la && ln -s ../libMOAB.la libMOAB.la)
Making all in oldinc
make[5]: Entering directory `/disk/itaps-buildslave/moab-shared/build/src/oldinc'
make[5]: Nothing to be done for `all'.
Making all in MeshFiles
make[3]: Entering directory `/disk/itaps-buildslave/moab-shared/build/MeshFiles'
Making all in unittest
make[4]: Entering directory `/disk/itaps-buildslave/moab-shared/build/MeshFiles/unittest'
Making all in io
make[5]: Entering directory `/disk/itaps-buildslave/moab-shared/build/MeshFiles/unittest/io'
make[5]: Entering directory `/disk/itaps-buildslave/moab-shared/build/MeshFiles/unittest'
make[5]: Nothing to be done for `all-am'.
make[4]: Entering directory `/disk/itaps-buildslave/moab-shared/build/MeshFiles'
make[4]: Nothing to be done for `all-am'.
Making all in test
make[3]: Entering directory `/disk/itaps-buildslave/moab-shared/build/test'
Making all in .
make[4]: Entering directory `/disk/itaps-buildslave/moab-shared/build/test'
Making all in io
make[4]: Entering directory `/disk/itaps-buildslave/moab-shared/build/test/io'
make[4]: Nothing to be done for `all'.
Making all in dual
make[4]: Entering directory `/disk/itaps-buildslave/moab-shared/build/test/dual'
Making all in obb
make[4]: Entering directory `/disk/itaps-buildslave/moab-shared/build/test/obb'
Making all in perf
make[4]: Entering directory `/disk/itaps-buildslave/moab-shared/build/test/perf'
g++ -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src/parallel -I../../src  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64 -DHDF5_FILE -DNETCDF_FILE -I../../src -I../../src/io/mhdf/include -I../../src -I../../itaps/imesh -I../../itaps -I../../itaps -I../../itaps/imesh -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -O2 -DNDEBUG -MT point_in_elem.o -MD -MP -MF .deps/point_in_elem.Tpo -c -o point_in_elem.o point_in_elem.cpp
mv -f .deps/point_in_elem.Tpo .deps/point_in_elem.Po
make[4]: *** No rule to make target `../../itaps/imesh/libiMesh.la', needed by `point_in_elem'.  Stop.
sincerely,
 -The Fathomatic
