[MOAB-dev] buildbot failure in Fathom on moab-32bit-handles
    moab-dev at mcs.anl.gov
    Sat Sep 25 00:09:46 CDT 2010
The Fathomatic has detected a failed build of moab-32bit-handles on Fathom.
Full details are available at:
 http://gnep.mcs.anl.gov:8010/builders/moab-32bit-handles/builds/236
Buildbot URL: http://gnep.mcs.anl.gov:8010/
Buildslave for this Build: gnep
Build Reason: The Nightly scheduler named 'nightly' triggered this build
Build Source Stamp: None
Blamelist:
BUILD FAILED: failed test
LOG EXCERPT:
g++ -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src/parallel -I../../src  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64 -DHDF5_FILE -DNETCDF_FILE -DSRCDIR=. -I.. -I./.. -I../../src -I../../src/io -I../../src/io/mhdf/include -I../../src -I../../src/parallel -I../../src/parallel -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -O2 -DNDEBUG -MT h5portable.o -MD -MP -MF .deps/h5portable.Tpo -c -o h5portable.o h5portable.cpp
h5portable.cpp: In function 'void test_read_vertices(const char*)':
h5portable.cpp:187: error: call of overloaded 'check_equal(const size_t&, moab::EntityHandle, const char [9], const char [13], int, const char [15])' is ambiguous
../TestUtil.hpp:333: note: candidates are: void check_equal(int, int, const char*, const char*, int, const char*)
../TestUtil.hpp:336: note:                 void check_equal(unsigned int, unsigned int, const char*, const char*, int, const char*)
../TestUtil.hpp:339: note:                 void check_equal(long int, long int, const char*, const char*, int, const char*)
../TestUtil.hpp:342: note:                 void check_equal(long unsigned int, long unsigned int, const char*, const char*, int, const char*)
../TestUtil.hpp:345: note:                 void check_equal(void*, void*, const char*, const char*, int, const char*) <near match>
../TestUtil.hpp:348: note:                 void check_equal(const char*, const char*, const char*, const char*, int, const char*) <near match>
../TestUtil.hpp:351: note:                 void check_equal(const std::string&, const std::string&, const char*, const char*, int, const char*) <near match>
../TestUtil.hpp:386: note:                 void check_equal(moab::ErrorCode, moab::ErrorCode, const char*, const char*, int, const char*) <near match>
h5portable.cpp: In function 'void test_elements(moab::Interface&, bool)':
h5portable.cpp:215: error: call of overloaded 'check_equal(long unsigned int, moab::EntityHandle, const char [22], const char [13], int, const char [15])' is ambiguous
h5portable.cpp: In function 'void read_sets(moab::Interface&, moab::EntityHandle*)':
h5portable.cpp:274: error: call of overloaded 'check_equal(const size_t&, moab::EntityHandle, const char [10], const char [12], int, const char [15])' is ambiguous
h5portable.cpp:280: error: call of overloaded 'check_equal(const size_t&, moab::EntityHandle, const char [10], const char [16], int, const char [15])' is ambiguous
h5portable.cpp: In function 'void test_read_set_contents(const char*)':
h5portable.cpp:312: error: call of overloaded 'check_equal(const size_t&, moab::EntityHandle, const char [10], const char [16], int, const char [15])' is ambiguous
sincerely,
 -The Fathomatic
