[MOAB-dev] buildbot failure in Fathom on moab-par
    moab-dev at mcs.anl.gov
    Sun Sep 19 00:07:25 CDT 2010
The Fathomatic has detected a failed build of moab-par on Fathom.
Full details are available at:
 http://gnep.mcs.anl.gov:8010/builders/moab-par/builds/274
Buildbot URL: http://gnep.mcs.anl.gov:8010/
Buildslave for this Build: gnep
Build Reason: The Nightly scheduler named 'nightly' triggered this build
Build Source Stamp: None
Blamelist:
BUILD FAILED: failed test
LOG EXCERPT:
the MPICH2 Installation Guide.
FAIL: uber_parallel_test
mpiexec_gnep.mcs.anl.gov: cannot connect to local mpd (/tmp/mpd2.console_jvporter); possible causes:
  1. no mpd is running on this host
  2. an mpd is running but was started without a "console" (-n option)
In case 1, you can start an mpd on this host with:
    mpd &
and you will be able to run jobs just on this host.
For more details on starting mpds on a set of hosts, see
FAIL: scdtest
    mpd &
FAIL: pcomm_serial
    mpd &
FAIL: parallel_hdf5_test
    mpd &
FAIL: mhdf_parallel
    mpd &
FAIL: parallel_write_test
8 of 8 tests failed
sincerely,
 -The Fathomatic
