[MOAB-dev] buildbot failure in Fathom on moab-par
    James Porter
    jvporter at wisc.edu
    Fri Sep 17 12:18:58 CDT 2010
This should be fixed. I forgot to restart mpd when I restarted all the
other buildbot stuff.
- Jim
On Fri, 2010-09-17 at 00:07 -0500, moab-dev at mcs.anl.gov wrote:
> The Fathomatic has detected a failed build of moab-par on Fathom.
> Full details are available at:
>  http://gnep.mcs.anl.gov:8010/builders/moab-par/builds/272
> Buildbot URL: http://gnep.mcs.anl.gov:8010/
> Buildslave for this Build: gnep
> Build Reason: The Nightly scheduler named 'nightly' triggered this build
> Build Source Stamp: None
> Blamelist:
> BUILD FAILED: failed test
> LOG EXCERPT:
> the MPICH2 Installation Guide.
> FAIL: uber_parallel_test
> mpiexec_gnep.mcs.anl.gov: cannot connect to local mpd (/tmp/mpd2.console_jvporter); possible causes:
>   1. no mpd is running on this host
>   2. an mpd is running but was started without a "console" (-n option)
> In case 1, you can start an mpd on this host with:
>     mpd &
> and you will be able to run jobs just on this host.
> For more details on starting mpds on a set of hosts, see
> FAIL: scdtest
>     mpd &
> FAIL: pcomm_serial
>     mpd &
> FAIL: parallel_hdf5_test
>     mpd &
> FAIL: mhdf_parallel
>     mpd &
> FAIL: parallel_write_test
> 8 of 8 tests failed
> sincerely,
>  -The Fathomatic
